why does it die? '99 f150 confusion...
then, i relaced the cam shaft sensor, as a recent code check indicated needed to be done, but was still experiencing the same problem with the same sounds. the starter engaged but then nothing happens. my oil temp, theft (flashing) and battery lights then turned on. upon further investigation i identified the area causing the problem, once again, as the ignition coil. it had cracked open, and melted from the inside out. i replaced it not once, but twice that day with the same results. i don't know what could be causeing this to happen, but i know it's not the coil.
having exhausted my limited automobile knowledge i finally decided to take it to the shop where they told me there was some hardend 'residue' in the mount for the ignition coil that may have been causing it crack, and inevitably blowout, when tightening down the bolts. this was also the cause of the blown fuse (specifically a 30amp minifuse located in position 30 in the cab fuse panel which powers the passive anti theft transceiver, cluster, ignition coils, powertrain control module relay).
i was skeptical of such a simple fix, but it drove fine. unfortunately that only lasted a day before frying the new coil, blowing another fuse, and loosing all powersteering going 70mph. i managed to safely pull it to the side and since i was traveling i got a new ignition coil and replaced the fuse just to get it off the side of the interstate and hopefully home. got 2-3 miles up the road before the coil melted out again. the only things i can think this could be would either be the relays or the spark plugs/ignitors. im not terribly skilled so any other ideas would be greatly appreciated...?
Dave
Are the head lights extra bright?
Are the interior lights bright?
Measure the voltage at the battery.
After starting and running about 5 minutes it should be no more than 14.6 volts
I'm thinking the fuse blowing is an after effect when the coil cooks and the windings short out.
I would not keep putting coils in and running the truck until you get a handle on this because the PCM is switcing ground to operate the coils and could be damaged , then your in for a new PCM and all the hassle of getting it programmed beside the issue you have now.
The fuse blowing is saving your tail from more serious damage, like fire , losing the PCM etc..
Good luck.
