speedo gear
Old 02-20-2003, 06:52 AM
pashtrd's Avatar
pashtrd
pashtrd is offline
speedo gear
i need to know the formula to figure out which speedo gear i need. does anyone know this? i have a c6 8 teeth on speedo drive shaft. 4.10 gears, 27" tall tires. also where can i get the correct gear.
thanks
matt
Old 02-20-2003, 08:10 AM
steve83's Avatar
steve83
steve83 is offline
speedo gear
The Ford dealer should have a book, and there or a junkyard are the only places to get the gears.
Old 02-20-2003, 09:22 AM
pashtrd's Avatar
pashtrd
pashtrd is offline
speedo gear
i checked with my local Ford dealer. they were absolutely useless. they said that all the gears were color coded, and that they did not know how many teeth each color had.they also said they had no way of knowing which gear i would need. snce the car i am working on never came with 4.10 gears. or any formula to find out which gear i needed. i know there is a formula. i used it on another vehicle. i just cat find it online anywhere.
thanks
matt
Old 02-20-2003, 10:15 AM
StrangeRanger's Avatar
StrangeRanger
StrangeRanger is offline
speedo gear
No surprise there.
The formula you want is:
Driven gear teeth = (Drive gear teeth x axle ratio x tire revs/mile)/1000
In your case that's:
driven gear teeth = (7 x 4.11 x tire revs/mile) / 1000.
or T = .02877 x tire revs/mile
You cannot accurately calculate tire revs/mile from diameter. You need to look it up for your tires either on the manufacturer's site or at www.tirerack.com
PAwhiteboy
02-22-2017 12:12 PM
Don Vito
11-29-2016 08:44 AM
blk450er
09-13-2016 06:39 PM
hest_c
06-27-2016 10:43 AM
cleanLX
03-22-2005 10:34 PM
Quick Reply: speedo gear
