89?
Old Sep 6, 2010 | 11:38 AM
Vinford's Avatar
Vinford
89?
Picked up a 89 dually flatdeck 4x4.
Wondering what diesel engine it would have in it?
Old Sep 6, 2010 | 11:48 AM
1988FordBeast's Avatar
1988FordBeast
7.3L. no doubt.
Old Sep 6, 2010 | 11:53 AM
oreocreaming's Avatar
oreocreaming
if its factory engine then ya 7.3l. ive gotten a few of these trucks that the engines have been replaced. easiest way to tell is to look at the oil filler. if its molded into the ip gear cover then its 7.3, if its bolted to the front center of it then its 6.9
Old Sep 6, 2010 | 12:52 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Another way is the head bolts ...
A 7/16" 12 point socket fits the 6.9L head bolts.
A 1/2" 12 point socket fits the 7.3L head bolts.
Also on top of the block next to the left (us drivers) side of the IP housing is the engine ID, it has 6.9 or 7.3 in it ...
-Enjoy
fh : )_~
Old Sep 6, 2010 | 12:58 PM
fellro86's Avatar
fellro86
If that hadn't been swapped either... At this moment, there is a 7.3 timing cover on my 86 6.9... There is no surefire outside appearance to guarantee either.
Old Sep 6, 2010 | 01:17 PM
Vinford's Avatar
Vinford
Well I need to buy a clutch for it , so i imagine I need to know for sure what size it isd?
Did 89's come with just the 7.3?
Old Sep 6, 2010 | 01:52 PM
fellro86's Avatar
fellro86
It doesn't matter on the motor, more the transmission. If 5 speed ZF, you will have a dual mass factory, so you then have to decide if you want to stay with the dual mass, or go to a solid conversion.
And yes, as of 88, all factory installed diesels were 7.3 IDI.
Pheadrus
Apr 8, 2014 09:47 PM
seths89f150
Aug 13, 2010 08:01 AM
89f15o
Jul 10, 2009 11:35 AM
DixieOffroad89
Jul 3, 2008 01:16 PM
jan
Bronco II
Nov 19, 2003 11:38 AM
