Propane Conversion
Old Aug 21, 2010 | 10:09 AM
Knightruler's Avatar
Knightruler
Propane Conversion
I have a 1981 Scamper Camper(motor-home) built on a Ford E350 Chassis. It was converted to propane by the previous owner.
My problem is: After I shut down I can smell propane.
Why don't I smell it any other time? and what can I do to fix it?
Old Aug 22, 2010 | 11:42 AM
Bern_F150_4x4's Avatar
Bern_F150_4x4
You didnt mention is the propane smell is brief or constant with the engine off. I'm not going to go into the obvious life/safety issues here, my advice is to Identify the entire fuel system and then using a solution of dish soap and water, check all propane plumbing and equipment for leakage. You may need to perform the test a few times by location (engine, fuel lines/regulator, fuel tank) to "catch" the leak as it happens if it is a brief release of gas. Not something to be taken too lightly...
Old Aug 22, 2010 | 01:37 PM
Knightruler
The smell is brief after shut down. You have to be paying attention to catch it.
dukefan70
1997 - 2003 F150
Nov 7, 2018 12:11 AM
JackErnie
Aug 11, 2015 10:05 PM
JackErnie
Jul 25, 2015 08:16 AM
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 6, 2014 11:27 PM
newguy399
Jan 3, 2014 06:37 AM
