reverse lights out
Old Feb 16, 2003 | 05:50 AM
mic's Avatar
mic
reverse lights out
Hi, I need help, my reverse lights do not work, and the bulbs are not burnt out, fuses are okay, any suggestions
my truck is a 1993 F150 flareside xtra-cab with a e40d trans
and a 302 eng. 4x4...
Old Feb 16, 2003 | 08:47 AM
kc73's Avatar
kc73
reverse lights out
mic, i do not have a '93, but i would start with the neutral safety switch. it may need replaced or adjusted. should be on your tranny, i think. do a search for the switch here or in '87 to '96 and i bet you will find all kinds of info that will get you going. just to clarify, the neutral safety switch also activates reverse lights. good luck.
Old Feb 16, 2003 | 12:21 PM
Mil1ion's Avatar
Mil1ion
reverse lights out
*NOTE:
When I clean up a combination neutral safety/Back-up light switch,I use lacquer thinner,as it evaporates a without leaving a residue.
Clean it until ALL the Grease is removed.
Old Feb 16, 2003 | 03:29 PM
steve83's Avatar
steve83
reverse lights out
The switch for the E4OD is called the MLPS (Manual Lever Position Sensor) and it's on the L side of the transmission just above the pan. You can test it with a light by using the diagrams in a Haynes manual.
Old Feb 17, 2003 | 11:24 PM
MustangGT221's Avatar
MustangGT221
reverse lights out
I have a similar problem. I checked the fuses but found that the fuse for the backup lights is in the power distribution box under the hood and not on the fuse panel in the truck. Just wanted to make sure. I keep blowin fuses but I don't know where the short is.
