6.2L V8 Discuss the 6.2L V8
Old 11-21-2014, 06:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
2011+ 6.2 Exhaust
  #76
Old 07-25-2012, 07:55 PM
builtftough4.6's Avatar
builtftough4.6
builtftough4.6 is offline
Originally Posted by Gary Atsma
You actually get better scavenging and power gains thru a correctly-sized single exhaust setup, because that way, pulses from both sides equalize and everything flows more smoothly, actually creating less backpressure, and making more power.
And by the way, many cat-back systems are good for more than 10HP, but the main thing about a good exhaust system is it allows other mods to do their job more efficiently.
agreed .
on the cat back note. magna flow just pushes systems out. incorrectly sized..my 2010 4.6 was the same size as they are claiming the 6.2 to be..just a dumped 3" with a bullet. explain ?
  #77
Old 07-25-2012, 09:04 PM
Gary Atsma's Avatar
Gary Atsma
Gary Atsma is offline
Originally Posted by builtftough4.6
agreed .
It appears that both Magnaflow and Gibson like to use the same parts for a BUNCH of applications(saves on engineering, ya know....).
I find it hard to believe that the same system used for a 4.6 engine will do just as well behind a 6.2.
I noticed that Flowmaster's American Thunder system for Raptors and other F-150's w/ the 6.2 is a full 3-1/2" all the way out (I approve, for what that's worth...) and their American thunder system (louder than ForceII) for 5.0, 4.6, and 5.4 is 3" into the muffler then 3-1/2" out the tailpipe(the muffler has 3" inlet and 3-1/2" outlet). Apparently the 5.0 needs the inlet pipe to be no larger than 3" to scavenge properly. I've actually heard that the 4.6 and 5.4 actually like a 2.5" system for best low-end torque, as they are not as much a real deep-breathing engine like the 5.0 is. Anyway, my .02 worth....
  #78
Old 07-26-2012, 06:49 PM
08streetglide's Avatar
08streetglide
08streetglide is offline
oops, I posted this in the wrong forum...here is my redo
sorry I've missed this chat for a while but its been real busy at work. I created a short video showing what I have done with the Dynomax Y pipe. I've found the mod to help a bit in the power loss area, but there is still no improvement in the mpg area. I originally thought I gaind 1 of the 2 mpg I lost, but after driving it more that turned out to be not true. I will do 1 more mob to this thing before I throw the piece of crap in the garbage and put the factory resonator back on........all this just to get a better sound, grrr
Here is the link http://www.youtube.com/watch?v=U3BxNGveHLs&feature=youtu.be
  #79
Old 08-09-2012, 09:19 AM
RAPR's Avatar
RAPR
RAPR is offline
08streetglide,
Have you completed your second modification to your Y-pipe yet? I'm still trying to decide if I want to replace my front resonator with a 2-3/4"x3" Y-pipe and install a Doug electric cutout. If there is going to be a power/mpg loss by removing the resonator though, I may not opt for the mod.
Have you taken a look inside the front resonator to see what it consist of? I'm wondering if it is just an open can, a can with a perforated flow-thru pipe, or if it has baffles built in like a traditional muffler.
My other thoughts are, if removing the front resonator causes performance issues, should I just install my cutout after the first resonator...by putting it in the second resonator's place. I'm just not sure how much sound I'd lose due to the first big can.
  #80
Old 08-10-2012, 10:31 AM
RAPR's Avatar
RAPR
RAPR is offline
I ventured under my truck yesterday and noticed the exhaust system has banded connections on each side of the 'second resonator'. I will try to disconnect the connection between the two resonators to see if the exhaust note is attractive with only having the first resonator inline.
  #81
Old 08-12-2012, 02:22 PM
08streetglide
sorry RAPR...
Just got to the mod today (8/12/12), will post the updated video. I wont have any input on this mod until later this week. I see a few others have tried diff. systems that also replace the front resonator. Just curious what their findings have been.
Final Y pipe mod - YouTube
  #82
Old 08-12-2012, 02:25 PM
08streetglide
OH, and to answer your question....the first resonator is baffled like a muffler, not a flow thru like the smaller second resonator.
  #83
Old 08-12-2012, 03:11 PM
Gary Atsma's Avatar
Gary Atsma
I like how you made a very smooth transition through the "Y" section of the pipe. I can't help but think it should smooth the flow considerably, thereby eliminating or at least greatly reducing any turbulence that was messing up the flow in the previous setup. This setup even looks very "factory" to me, if you know what I mean. This should work, and I'd bet you even regain, or even improve upon, the "lost" fuel mileage AND low-end torque.
Keep us posted!
  #84
Old 08-13-2012, 08:15 AM
RAPR's Avatar
RAPR
RAPR is offline
Originally Posted by 08streetglide
sorry RAPR...
08streetglide,
If your new y-pipe design works, you might need to go on a short production run It looks really good, regardless of final performance.
  #85
Old 08-13-2012, 04:22 PM
Gary Atsma's Avatar
Gary Atsma
Originally Posted by RAPR
08streetglide,
I agree- it looks production-ready; the line forms to the right(of course...) guys
  #86
Old 08-14-2012, 03:36 PM
08streetglide
lol, well thank you guys, well, after 2 days of taking it to work, im back up to my 14mpg combo city/highway. and the low end torque is real good again!!! but the one thing that I've failed to mention in all of this is how it sounds. from day 1 of removing the front resonator, and thru the 2 mods, the sound on excel. is off. kind of has the sound of an old rotting out muffler with a hole in it. Maybe the MBRP flow thru muffler isnt the way to go either. I've been so consumed by trying to get the performance back I was hoping the sound would improve as I did the mods.....it has not . maybe a flowmaster baffled muffler would help that out?
  #87
Old 08-14-2012, 03:47 PM
RAPR's Avatar
RAPR
RAPR is offline
08streetglide,
You didn't happen by chance get to hear what the exhaust note sounded like coming straight out of the front resonator, without going through the rest of the plumbing?
I thought it was going to be easy disconnecting the piping between the 2 resonators, by loosening the metal band. Well I was wrong. I don't have enough slack to pull the connection completely apart, without removing uninstalling the rest of the factory exhaust.
Originally Posted by devongarver
You could save a lot of money by just removing everything behind the resonator. Sounds very clean, and nice and deep! I ran that for several days before removing the resonator too haha! Now it's loud just like I wanted...and the best part...it was all free!
I see that 'devongarver' did just that in an earlier post, and said that it was a nice deep tone. I'm just wondering on how loud it is, since I'm wanting to go with a cutout. I'd like it to be deep and loud, like the Raptor in the video I posted a while back.
  #88
Old 08-14-2012, 05:26 PM
08streetglide
not loud enough, thats why I got the Y pipe to eliminate the front resonator hoping for a louder sound. its louder on exceleration, but not a good tone as far as im concerned.
  #89
Old 08-14-2012, 05:44 PM
Gary Atsma's Avatar
Gary Atsma
Hey man, congrats on the good results! Like you said, now all you have to deal with is getting the right sound. My personal recommendation is a Flowmaster Series 50 or similar. Nice sound, but not TOO noisy. But you use your judgement. Good luck!
  #90
Old 08-28-2012, 09:12 AM
RAPR's Avatar
RAPR
RAPR is offline
Well, I finally got my exhaust cutout installed. I swapped out the section with the 2nd (small) resonator and replaced it with the cutout. I left the front resonator in place, as it is a pain to fabricate a custom y-pipe to replace it (as 08streetglide has demonstrated). There is no reason for all you guys to be spending the $ on an exhaust system that cost a few hundred dollars. This cutout produces the deep note that you are looking for. It stays fairly quiet at idle and low accelerator input, but when you give it gas it sounds amazing!
Right now I only have the cutout with a manual block plate, as I won't be able to install the electronic Doug valve until next week. With the cutout blocked, it sounds quiet just like factory.
Quick Reply: 2011+ 6.2 Exhaust
