Door won't shut after new weatherstipping installed..
I installed some new weatherstrip on my passenger door this weekend. I have done the drivers door with the same weatherstrip and all I had to to was adjust the striker out a bit and it closes fine. The passenger is a different story. For the life of me I can't get the darn door to shut unless I adjust the striker all the way out and then it barely closes with a lot of force and the door sticks out past the cab-mostly at the bottom of the door. Any ideas? The striker is in perfect shape.
Yes that's normal. It will take some trial and error so I know it's hard but be patient. I litterly had to slam my doors for months and that was last year. I even took a heat gun to them but be careful you don't get to close, you can discolor your paint or start to melt the w/s. I would personally put the striker back in the original spot and even though the doors will still be out abit leave them there for awhile. I've been through this as well as other members so we know how fustrating it is.
Thanks for the words of encouragement. I know the striker was moved inward by someone before in order to cope with the collapsed/rotted weatherstrip as the door shut easily, yet set inside the cab frame too far.
At some point I will need to align the doors as it looks like the door and front fender rub a small bit on the lower front section when the door is opened.
we just put new weatherstripping in my daughter's 65 mustang and yeah it made it really tough to close the doors. As much as I hate even mentioning the word "silicone" as I'm a body/paint guy...
I was told to use silicone on the rubber (weatherstripping) well I didn't have any nor did I want any silicone spray around but we had some armor all at home so we used that.
It helped a lot. I sprayed it on a cloth then wiped it on the weatherstripping. now a couple months later the weatherstripping seems to be broken in and the doors close really nice.
