hi I have been chasing ever changing computer codes both Koeo and Koer, i have checked everything wiring harness connectors...
finally measured the negative battery terminal clamp to to ground was .6 ohms and from the battery post to ground was over 20 ohms.
cleaned the post real good and applied a layer of axle grease.
