Milling Heads
Old 08-08-2010, 09:26 PM
FossenRacing's Avatar
FossenRacing
FossenRacing is offline
Milling Heads
How much can 390 heads be milled down?
they are 72te heads.
will be putting in bigger intake and exhaust valves, and also port and polish.
and after i mill the heads will the intake need to be milled also?
Old 08-08-2010, 11:14 PM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
It is better to use pop up pistons that do major head cuts. Two reasons, first if the high compression does not it work out, putting material back is real hard. And the biggest reason is if you cut the head a lot, then you have to cut the intake and then it is no good on any other engine.
Old 08-08-2010, 11:57 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
You should look for a pair of '67 or '68 390 GT heads, I think they have smaller combustion chambers and bigger valves. Most real truck heads have heavy valve rotators which helps for endurance in heavy trucks but are heavy and limit the usable rpm available.
Old 08-09-2010, 01:11 AM
Bear 45/70's Avatar
Bear 45/70
The 390GT head is exactly the same as the standard heads except for the staggered exhaust bolt holes.
Old 08-09-2010, 11:56 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Or, cut the intake side of the head, and use RTV at the end-seals.
Old 08-09-2010, 03:58 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
The cutting should be done only by a well qualified machinest in a good shop. If not you could end up with a real mess and no recourse.
Old 08-09-2010, 04:30 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
That can be said about ANY machine work.
Old 08-09-2010, 08:45 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
That is true, but most peop[le just accept that a machine shop is a machine shop and they know what they are doing. HA!
