What did you do to the X today?
#1351
Received 5,172 Likes
on
#1352
#1353
hey guys, new here
I finally upgraded from my f150 to this hoss
2000 Limited, leather, 104k, v10 4WD
first order of business, tunes. radio station selection here in western NC is dismal
hoping to get some more mode soon, maybe a bull bar with fog lights and different things
As soon as I get a better idea what my schedule is for the rest of the year, I'm gonna try to plan a GTG at my place - maybe the first weekend in November???
Anyway, I'll PM you my contact info - I dunno much about them gas-guzzlers, but I'd be happy to help if you ever needed a hand!
on edit: no PM's for you until ya get 25 posts... this is a good thread to 'chit chat' and build up your post count, but don't be afraid to post a "good job" or "I like your truck" in other threads as well. Also notice the little heart at the top right of every post? Clicking that and providing positive feedback (aka 'reps') for a post is a nice thing you can do to show you 'like' a post. The little green squares represent how many 'reps' a member has received.
#1354
I put the roof antenna on the drivers side and ran the wire thru the drivers side rear window (which i will try not to use hearing all these stories on here lately!) I tucked the wire along the ceiling and down the pillar to underneath the steering wheel. In the fuse box I used an Add-A-Line fuse and wired up a 3-way cigarette lighter to a keyed power source. That way I can plug up my gps ect as well. From there I popped out the radio (no dash removal needed ) and pulled the wires up and to the top corner, and bam. Nice, clean install. An identical setup is in my F150 so I can swap the radio out easily
#1355
Congrats and welcome to FTE!! I'm right down the road from ya in Blairsville, GA and get thru Franklin all the time. In fact, wknd after next we'll be dragging the Toy Hauler up to an FTE get-together in PA and will drive right by ya on Thurs eve. We have a few FTE members in N. GA and several up in eastern TN - mostly PSD's, but we are not tooooo prejudice!
In a perfect world I wouldve bought the diesel in a heartbeat; but with a real world budget I got the v10. One things for sure I did NOT want to go another winter without 4 wheel drive! I'm happy with it though, the interior room is unbelievable. Definitely let me know about your get together, if its not a weekend I have to work I'll take a little trip down to GA. Love the cheaper gas down there haha
#1356
#1357
#1358
on
#1359
#1360
I have to do this, do you have any info or a walk through that you used? Mine hasn't worked since I bought the truck and I haven't been able to get it to work.
#1361
i wish i took pics but i think i can do i quick step x step
1 remove lower liftgate plastic panel
2 remove rod from rod clip on back of the liftgate lock mechanism
3 remove large clip wire holding lock unit in around the body of lock with a flattip screwdriver and some needle nose pliers (easier then it sounds, might just use flattip)
4 take eclip off back of mecanism now that its out to remove arm with rode clip from back of lock mech
5 now carefully pry chrome keyhole end surround off lock mechanism
6 pry keydoor flap off with flattip screw driver, careful as a spring is behind this and might get lost.
7 tap the long end of the lock mech with a scredriver handle to knock it thru the mech body, careful again as there is a pin with another spring in there.
8 soak body in clr for a couple hours, not days or the clr will eat it, you will see the clr immediatly begin to go after the rust as it will bubble (CLR = CALCIUM, LIME, RUST REMOVER FROM THE STORE)
9 rinse with water try to take a flattip and free the copper keys in the tumbler with a flattip pushin from the back side the less wide side of the copper looking flat, another flattip screwdriver use, soak longer if still stuck, becareful again as each of the copper pieces has a small spring under the wide side.
10 once you got it working good lube the heck outa it and reassemble in revers order.
congrats you got a working lock system.
#1362
#1364
