What did you do to the X today?
  #9031
Old 08-07-2012, 07:36 PM
archtaan's Avatar
archtaan
archtaan is offline
Neither was I in that regard. I did have the factory plastic card in the owners manual packet though so I did luck out!
  #9032
Old 08-07-2012, 07:55 PM
riggers's Avatar
riggers
riggers is offline
My second X the dealer told me the code when I bought it.
  #9033
Old 08-07-2012, 08:28 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
i drove mine to work and back lol on my way home i followed a '05 that was crab walking pretty bad. hard to see in the pics but the rear was steering it pretty far to the right. i could see the whole drivers side going straight down the road.
  #9034
Old 08-07-2012, 09:02 PM
LunaticSVT's Avatar
LunaticSVT
LunaticSVT is offline
Originally Posted by riggers
Isn't the door code on a sticker under the dash somewhere? I'm not sure but on my first X I made a list of all possible door codes based on 1-5 and it really isn't that many when you do it that way. It took me all of about 1 hr once I started going through them.
Most trucks yes. I had my dash apart for some custom stuff I was working on and searched and searched and found nothing but a blank sticker where everyone said it was at. Looked at all the posts on where it was at. I was about to do the string entry, but when the truck went to Ford I just called the adviser and he said he will hook it up before I get there and pull it for me!
  #9035
Old 08-07-2012, 09:08 PM
riggers's Avatar
riggers
riggers is offline
Sweet Lunatic. Desperate measures and all! I need someone OCD to come clean my land, and beat my children. How dare they take crap outside, leave it there, and let it do all that mess. GRRRR
  #9036
Old 08-07-2012, 09:15 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
I NOTICED ALLOT OF EX'S GO DOWN THE ROAD LIKE THAT
  #9037
Old 08-07-2012, 09:21 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i've never seen a Ex do it, but alot of pickups. dodges seem the worst about it.
  #9038
Old 08-07-2012, 09:30 PM
Sunline Fan's Avatar
Sunline Fan
Sunline Fan is offline
Excursion Fleet Manager
Ditto. I've seen some SRW F250/350s doing it pretty bad too.
  #9039
Old 08-07-2012, 09:36 PM
aortizexcursion's Avatar
aortizexcursion
aortizexcursion is offline
Same here...I've notice some Super Dutys do that. Why or how does it happen?
  #9040
Old 08-07-2012, 09:37 PM
BadDogKuzz's Avatar
BadDogKuzz
BadDogKuzz is offline
Originally Posted by robbragiel
The wife has my truck down in FL and I drove the X back up to SC to do all the stuff I needed to do. I hope she dont wreck my truck. Shes not that good with a long truck like mine. The left front rotor was warped on the X so now everything works great. I am scare for you. Just tell her " Please no drive thru's" Them poles they put around building seem to jump out in front of my wife too.
I still need to swap out the springs for the V & B springs because whats on there now is real tired.
I have a vacuum leak somewhere because when I switch to 4x4 it automatically defaults to defrost.
Left side back seat door has 3 small dents from when she pulled up to a ATM hit the pole next to the ATM machine. I should be able to pull the door pnl and try and push the dents back out. There not creased so I should be able to do it if I can access it. If you can't get them out with your hand I have found in the past if you use the back side of a screwdriver handle and work it or massage from the center of the dent out it instead of beating it out works nicely most of the time.
New shocks, shoes, tuner, 6.0 tranny cooler and a new intercooler. Other then that, that should be about it for modding the X until something breaks hard.
What tunes are you going with? And what intercooler are going with ?
  #9041
Old 08-07-2012, 09:40 PM
riggers's Avatar
riggers
riggers is offline
Hubby used a toilet plunger. A little tiny one he had bought. Pulled em right out. LOL
  #9042
Old 08-07-2012, 09:55 PM
BadDogKuzz's Avatar
BadDogKuzz
Well in most cases it is either the rear diff isn't square to the frame a 4wd alignment will tell you if the rear diff has negative on rt side rear and postive toe on left side rear. Or the wheel base is off. One side is longer than the other. And lastly the other most common reason is the vehicle has frame damage and was not repaired correctly. It is sad to say that in this day in age most body shops don't use nothing more than a tape measure and tram when straightening frames. Also they are using way to much heat on these frame rails. Ford has said since around 1999 that no more than 600* heat can be used to repair frame rails. And that is NOT glowing red with a rose bud.
  #9043
Old 08-07-2012, 10:19 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
its allot more common when the vehicle has lift "blocks" in the back, the right rear tire drives the vehicle, pushing the right side of the axle forward due to the flex of the block leverage on the drive side. taller the block, the more crabwalk when accellerate
  #9044
Old 08-07-2012, 10:44 PM
wildstang's Avatar
wildstang
wildstang is offline
VT Chapter Ldr
Originally Posted by archtaan
On some trucks if you are really lucky you can see it in the modules by the radio. Not all of them though. The dealer can get the code with their scan computer.
Supposedly 02 and up have the sticker with code, but not sounding like a guarantee. My dealer wanted like $100 to scan the code, screw them
  #9045
Old 08-08-2012, 01:26 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
cant you scan the code with the AE?
Quick Reply: What did you do to the X today?
