What did you do to the X today?
  #42226
Old 05-23-2016, 08:00 PM
orlando128's Avatar
orlando128
orlando128 is offline
Just order a EBPV delete kit from Garret
  #42227
Old 05-23-2016, 08:14 PM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
Set the Ex back to its stock programming as I have to take it in for an emissions check soon. So I will drive it for about a week or two, then in she goes with fingers crossed that she will pass her first emissions check as required by the nut jobs here in the Seattle area...
Wish me luck.
  #42228
Old 05-23-2016, 08:19 PM
High Cetane's Avatar
High Cetane
High Cetane is offline
Originally Posted by Snowseeker
You know, looking at the pic it almost looks as though it is rubbing on something. Is there anything up in "the hole" that looks like it was also being rubbed on?
Man I wish....sure would make things easier. I got the tank back up tonight.
Better living thru chemicals. ( Me, not Rocky )
  #42229
Old 05-23-2016, 08:46 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
Wish me luck.
Good luck !
If it makes you feel any better..... we have NO emissions testing over 7500lbs. Under 7500 is just an OBDII test, no visual. No check engine light, you pass.
  #42230
Old 05-23-2016, 09:05 PM
nmclella's Avatar
nmclella
nmclella is offline
No emissions checks here...
Bought myself a Winchester 64 today, very happy with it so far.
  #42231
Old 05-23-2016, 10:56 PM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
Originally Posted by IMASAP
Good luck !
This place is weird, there are emissions checks in only a few counties (those around Seattle) and for diesels, if you are older than 2007 and weigh MORE than 6001lbs, then you MUST get tested. http://www.emissiontestwa.com/e/faq.aspx#2
  #42232
Old 05-23-2016, 11:19 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
I need to go through my front spring swap, few hundred miles since I installed them so I need to go check all the bolts. Got a few noises and clunks today which were not there yesterday.
  #42233
Old 05-24-2016, 12:13 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
hauled a round bail of straw
  #42234
Old 05-24-2016, 12:45 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
This place is weird, there are emissions checks in only a few counties (those around Seattle) and for diesels, if you are older than 2007 and weigh MORE than 6001lbs, then you MUST get tested. Washington Vehicle Emission Check Program - FAQ
We are in constant competition with Kommefornia.
From last Wednesday hauling a smaller shed and some 12" sq pavers. The hill I was driving up was pretty steep and I usually just hammer the gas.
  #42235
Old 05-24-2016, 01:17 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by orlando128
Just order a EVPB delete kit from Garret
Exhaust Back Pressure Valve, EBPV.
Don't worry, I never get it right unless I say all four words...S L O W L Y...in my head first, then I get the acronym correct!
I gotta ask you tho, to whom was your post directed? We have no clue who your post was talking to because you didn't quote them.
I thought Cali was bad, but....umm....really? Older than 2007? What the heck do they check when a 1996 OBS rolls in, or a pre-powerstroke IDI?
Stewart
  #42236
Old 05-24-2016, 06:53 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Originally Posted by 2005 Ex Limited
When it rains; it pours. Use that water to put out the fire.
Looks like it got kinda hot under there. Does this count as a custom mod? But on a lighter note I started powder coating and I did the intake.
Not too bad for my first time. Small blemish on the underneath side, but no one will see that ever. And I got an elbow anyway, so if anyone is interested in this...
Is that your X? What happened? Why is the battery still hooked up?
  #42237
Old 05-24-2016, 07:05 AM
mecdac's Avatar
mecdac
mecdac is offline
Wish me luck.
Good luck !
Stewart
No cat, no test. In GA if you don't have a catalytic converter there is no smog test. Any other vehicle pre-1990 is exempt.
Freedom smells nice.
  #42238
Old 05-24-2016, 08:41 AM
"Phatman"'s Avatar
"Phatman"
"Phatman" is offline
Originally Posted by Jmatthews
I wish we had an In-N-Out here in NC, wouldn't miss McD's I don't think.
I second that
  #42239
Old 05-24-2016, 08:09 PM
High Cetane
These found me on CL...
...and channeled my Inner-Brent.()
Every intention on a particular Fuel wheel in the near future too. It was an offer I couldn't refuse....
  #42240
Old 05-24-2016, 09:05 PM
mecdac's Avatar
mecdac
mecdac is offline
Talking
I love bright shiny objects...
Quick Reply: What did you do to the X today?
