What did you do to the X today?
  #33571
Old 03-30-2015, 06:38 PM
01 EX PSD's Avatar
01 EX PSD
01 EX PSD is offline
Jmathews: I adjusted mine and got 6 more months out of it before it became unsafe. The X would wander from fog line to center while keeping the wheel straight. Lot of people recommend redhead but I went with a cardone one due to budget. It's pretty straight forward install. One thing I learned the hard way, rent a medium/heavy duty adjustable pitman arm remover. Nothing like finding out you rented the wrong tool when your truck is in pieces lol.
  #33572
Old 03-30-2015, 08:14 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
Nice little check arrived today from Conoco. Time for the upgrades to begin!
  #33573
Old 03-30-2015, 08:26 PM
mecdac's Avatar
mecdac
mecdac is offline
HUH, It seems to me I remember someone telling you it would work out in your favor.
Good for you buddy, glad it came through.
  #33574
Old 03-30-2015, 08:31 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Originally Posted by IMASAP
To be honest, the reason I haven't ordered an air tank yet is because I parked the truck for the winter and until about a week ago it still had ice and snow under it. I've been too lazy to get wet laying under there to figure out what size tank I can fit, and where. I'll likely tee into each side with two electric over pneumatic solenoids, one to fill and one to dump. No idea what compressor I'll use yet. Not looking to run air tools, but will want to be able to fill tires and such. I'll gladly do a write up when I do the install. Next project is to install my Pro Comp 22210 front springs and my new tires should be here in the next day or two, so the compressed air will be after that.
I'm running a dedicated air compressor with No tank for the suspension, then running a second compressor into a tank for train horn, air hose etc. I really like the setup if one compressor goes down, it takes about 5 minutes to exchange function. Installer also put in a manual lead for the airbags for a 3rd option.
  #33575
Old 03-30-2015, 08:38 PM
nmclella's Avatar
nmclella
nmclella is offline
Got this in the mail today.
Got it on, tried to do it without draining any coolant. THAT WENT WELL as a couple liters of coolant ended up on my floor. Got it done and refilled up to appropriate levels. Filtering now and no leaks.
Success!
  #33576
Old 03-30-2015, 08:42 PM
AzPatMan's Avatar
AzPatMan
AzPatMan is offline
Originally Posted by truck7575
Just looked at the instructions for my MaxTow Glowshift fuel gauge and it says the dimmer function needs the orange wire to go to the 12V positive headlamp source.. anyone know the color wire and its location?
There's technically two that you can use.
1) on the panel there is a color coded dimmer wire that you splice into by your head light switch. A little google searching and you should be able to find which one it is.
2) Since I had my radio out to wire in a new one - there is also a dimmer wire there you and use as well. I used this one.
  #33577
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Lucky me my brother in law has a shop in town, might just borrow his heh heh.
  #33578
Old 03-30-2015, 08:58 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
Its nice that with air systems you can get creative for little money. With a few fittings, air line, and a ball valve you can keep your two systems separate, yet tie them together in a pinch. I'm also going to keep my manual fill valves, and my air tank will have one as well. If needed I'll be able to air up at home, at a gas station, or wherever.
  #33579
Old 03-30-2015, 08:59 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Hell yeah man! Glad that's done and over with
  #33580
Old 03-30-2015, 09:47 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
Nice, glad it finally worked out.
I'm helping them spend their money (they have plenty of it) with lots of new truck upfits. $475,980.00 in PO's today.
  #33581
Old 03-30-2015, 09:56 PM
Krazee Matt
Getting the check today was a HUGE relief... I went out of pocket on the repairs (upgrades actually, was way cheaper that way).
It's going into the trans bulletproof rebuild Roland (mueckster) and I are doing, plus a 38R and billet wheel, T500, and hi-flow CVD's and banjo bolts from Clay.
The leftovers will go back into the Chevelle build fund. Took a hefty withdrawal from them for the engagement ring, but it was totally worth it (no fu****g jokes, family is off limits). I'll never sell the car, so I have time. I just need to finish the short block while I'm at school so I can get the monster discounts on the rotating assembly and finish up the machine work.
  #33582
Old 03-30-2015, 10:39 PM
Apocalypse's Avatar
Apocalypse
  #33583
Old 03-30-2015, 10:47 PM
superdave02f552's Avatar
superdave02f552
superdave02f552 is offline
Just stopping in to say hi I have not been around much, hooked the EX the manlift and that's about it. I will hit it hard when it's nice and warm......also I got my fingers on a 6.0 and a 5r100 I wonder what I can do with those?????
  #33584
Old 03-30-2015, 10:51 PM
InmatesRunThePlace's Avatar
InmatesRunThePlace
InmatesRunThePlace is offline
Originally Posted by Apocalypse
Thx for the vid. Since you already had a bar on there was it just a remove and replace w/ new brackets?
  #33585
Old 03-30-2015, 11:20 PM
Apocalypse's Avatar
Apocalypse
No, everything from the OEM swaybar was removed before I got the truck (Member in TX. needed one and I didn't so he removed it before it was shipped to me) so it was as if there was never one at all. Everything you need (except decent hardware) is included with the kit.
Quick Reply: What did you do to the X today?
