F150 Radio question
F150 Radio question
First hey all. Newbie to the forum.
I have just purchased and 04 F150 Supercab 4x4 and I wanted to hook my iPod up to it. So I searched around a little and came across BlitzSafe FORD/CAN m-Link2; which according to the website is compatible with my year. Well I installed it and it didn't work. I did some more searching and found that my radio which is a 5L3T (?) doesnt have the internals to work with it. I read somewhere that the radio model 6L3T is compatible with it.
Is that model compatible with it?
If I buy the 6L3T radio will I easily be able to swap it out?
If you are looking to control the iPod from the head unit, you will be unable to with what you have.
If you simply want an AUX in where you can charge listen to your iPod while controlling it from your iPod directly, look at USA-Spec and iSimple.
Good luck.
Swapping out your head-unit is also an option.
I know 04 was a tricky year as far as what head unit they used but give USA-Spec a call. I have used them in the past, solid no nonsense product.
I had an iSimple in my Tacoma and it was pretty good as well.
Good luck.
Good luck.
Good luck.
spatengal
1999 to 2016 Super Duty
07-01-2013 10:52 AM
mrferg
05-27-2011 07:25 AM
drobins9
1997-2006 Expedition & Navigator
01-17-2006 10:14 PM
