Flathead V8- valve seat and rings
Hey Freakboy
I luv dreaming and then I gots to work, but got a question. What kind of Bovine feces; Ox, cow, buffalo or what. I like to know what is getting dumped on me. HeHeHe
racear
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
racear
Hey Youall
I do have Steve's motor on the dyno as we speak. I am only letting the dyno run it thru breakin. Has any body ever seen what kind of torque or HP numbers one of these thangs actually make. I dont want to lean on it hard because I did build it pretty tight for it to last longer and I dont want to score a cylinder. Steve would kill me.
racear
racear
Hey Freakboy
racear
racear
Hey Freakboy
I did a engine for a 78 Ford pickup a couple years back. As I recall, it had a 351M in it. I converted it to a 400M and put a stroker in. He wanted it to look stock but wanted it to be pepped up. We re did the heads and di quite a bit of work on the intake and exhaust manifolds. Didnt help the HP much but sure did make dang good torque. But every thing inside the engine is heavy. It ran good to about 4800 and then fell off a cliff
racear
racear
Hey Freakboy
racear
racear
Hey Youall
racear
<!--Session data-->
racear
<!--Session data-->
Here is a flatV8 dyno run with a 3/4 cam
http://image.streetrodderweb.com/f/8...lame33zoom.jpg
It is a 3 ring piston. Cylinders were prepared at 280 grit and then back feathered. Did not have a torque plate(making one for the next engine) so put hardened washers under bolts and torque them down so try to simulate torque pull on the walls. Running engine at 180 so cylinders will fully expand. At 160 block will not expand as much as it will at 180. Ran oil under 190 degrees. Took about 30 minutes and friction and blow by began to dissipate. Really controlled the air fuel ratio so not to wash cylinder walls down or overheat them. Ran vacuum motor on it to pull engine under vacuum. Ran some methanol so as to slow down the burn.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
I'm sorry. I didn't explain very well.
1: It is a 3 ring piston
2: I prepped the bock with final hone of 280 grit
3: I then used a carbide feather duster and brushed the bore in reverse to plateau hone it(this is crushual)
4: I forgot to mention that I ceramic coated the heads so as to hold heat in the combustion chamber
5: When I fire the engine we control the engine to 180 degrees. 160 will not let the cylinder expand to max. When we prep the block, we clean around the cylinder with acid so that block will cool properly. Here a risk is involved, even if you sonic check, if there is a gas hole, the acid will burn thru.
6: We use Joe Gibbs break in oil with huge amounts of zinc diphosphate to reduce friction
7: We never let the engine get under 2000rpm
8: We fire with a vacuum motor attached to the engine so that the rings will not build up back pressure and unload until they seat
9: Since I did not have a torque plate for this engine, I tried to simulate bolt torque out of roundness when I honed it by putting bolts in the head bolt holes and torquing to spec(not as good as a torque plate because a gasket is not there)
Crap, did I miss any thing
racear
racear
fat otis
02-21-2015 07:53 AM
Zac2zac2
26
12-02-2014 10:39 PM
ALBUQ F-1
63
10-17-2013 12:50 AM
