P0420 code
Old Jul 27, 2010 | 11:38 AM
hillclimbin's Avatar
hillclimbin
P0420 code
My cel came on and the code is p0420 which is the cat on bank one, my question is what side bank 1 is on, the driver or passanger side, i was hoping it would be a bad 02 but the 02s would throw a different code right?
Old Jul 27, 2010 | 12:21 PM
kevincw's Avatar
kevincw
What year, engine and milage do you have?
Old Jul 27, 2010 | 12:25 PM
kevincw's Avatar
kevincw
A code P0420 may mean that one or more of the following has happened:
Leaded fuel was used where unleaded was called for
An oxygen sensor is not reading (functioning) properly
The engine coolant temperature sensor is not working properly
Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
Retarded spark timing
The oxygen sensors in front and behind the converter are reporting too similar of readings
Old Jul 27, 2010 | 12:29 PM
hillclimbin
its an 04 5.4 90k..i thought the 02 sensors had there own code?
Old Jul 27, 2010 | 12:33 PM
kevincw's Avatar
kevincw
They do have there own codes, it doesn't always mean that the sensor it bad. The code can be caused by numerous conditions, like a vacuum leak. Did the light just come on? Has the truck been running rough? Did you run over anything that could have damaged the wiring to the sensor? Fill out your information and state, join a local chapter.
Old Jul 27, 2010 | 01:01 PM
hillclimbin
The light came on a few days ago, but the truck is running good,2 weeks ago i cleaned the throttle body with some throttle body cleaner, but i cant see that messing anything up.
Munky
1997 - 2003 F150
48
Jul 1, 2014 05:25 PM
amill
1978 - 1996 Big Bronco
Nov 8, 2012 03:20 PM
dixiestripes351
1997 - 2003 F150
Jun 15, 2011 11:52 PM
kjk
Aug 12, 2010 11:37 AM
jseim44
1997 - 2003 F150
Jun 22, 2006 06:36 PM
