help leaking
Old Jul 26, 2010 | 04:24 PM
dmeyer 351 4x4 rebel's Avatar
help leaking
some thing leaking in drum not the wheel cylinder dont no if its brake fliud or gear oil its clear blue ish tint
Old Jul 26, 2010 | 04:33 PM
need help please
Old Jul 26, 2010 | 04:49 PM
93_flareside's Avatar
93_flareside
If its not the wheel cyl, its gotta be the axle seal. Does the fluid smell like gear oil? wheres it coming from?
I'm pretty sure there are only two types of fliud that can be in the drum, brake fluid, and gear oil.
Old Jul 26, 2010 | 05:34 PM
ya it gear oil how do i fix the axle seal?
Old Jul 26, 2010 | 05:45 PM
LCAM-01XA's Avatar
LCAM-01XA
If it's clear bluish and smells like gear oil then someone must have recently done an oil change on the axle, too bad their efforts are going to a waste with that leaky seal there. In order for us to tell you how to fix the leak, we need to know what truck you have, and in particular what rear axle (8.8", 9", D60, 10.25" semi-floater, D70, or a 10.25" full floater)?
Old Jul 27, 2010 | 01:05 AM
its 92 f150 4x4 351w axle not sure prob stock
Old Jul 27, 2010 | 01:20 AM
ya has to be stock
Old Jul 27, 2010 | 01:22 AM
LCAM-01XA's Avatar
LCAM-01XA
You got the 8.8, done a few of those, real easy:
1) remove wheels
2) remove brake drums
3) open differential cover, drain oil
4) find the bolt for the differential cross shaft and remove it (there is a thread-lock compound on it so heating the diff case helps a lot), slide the cross haft out of the diff case
5) push axle shafts in as far as they'd go, remove c-clips from the diff, pull axle shafts all the way out of the axle tubes
6) yank the old seals out, gently beat the new seals in
7) reinstall everything in reverse order (don't forget smearing some thread-locker on the cross shaft retaining bolt), fill the axle up with oil, you're done
This would also be a good time to replace the axle bearings, inspect the axle shaft surfaces where they ride on for wear.
Old Jul 27, 2010 | 08:22 AM
93_flareside
If your going to check the axles and change the bearings, a good way to clean the tubes is to make a powered extenable, radious nylon brush... aka toilet bowl brush on a stick.
Old Jul 27, 2010 | 02:49 PM
thanks guys got them out going to go put them in
Old Jul 27, 2010 | 06:21 PM
got a bigger problem seem like some one down the line mess it up and got the rear end rear bearing replacement set up wtf any one kno any let me kno asap thanks
Old Jul 27, 2010 | 06:59 PM
LCAM-01XA's Avatar
LCAM-01XA
Wait, what now? What exactly is the issue?
Old Jul 27, 2010 | 07:45 PM
93_flareside
whiskey tango foxtrot?
Old Jul 27, 2010 | 08:49 PM
a no went to advanced auto and got replacement seals got home got the old ones out and they were to big so went back they were stumped spent a hour or two in their they looked on comp at all the other seals going back to the 80s then a last thought the guy got out a replacement seal/ bearing kit and had the same seal as the one we pulled out but the kit has the hole bearing and **** in it
Old Jul 27, 2010 | 09:48 PM
LCAM-01XA's Avatar
LCAM-01XA
Sounds like someone installed a repair bearing/seal kit in the axle tube, this effectively moves the bearing outboard some and makes it ride on a part of the axle shaft that is not normally used - IIRC those things use smaller seals on them, so to use the original-size seal (which is probably what you got at the parts store the first time around) won't fit. You'll have to yank the old bearing set out before you can install new bearings and seals. What's the part number on the box for the new bearing/seal kit you got now?
