351 motor with a autotmac tranmission for a 4X4 F-250 pick up truck. you know how young boys are, he would like to put a 460 with a tranmission into his truck. But I would need the complete wiring for a 460 motor.
Carlisle is this weekend if you willing to travel a little. I'm sure you could find something there. Also check out the WV chapter. You will be able to get intouch with local guys and could come across a good find.
I see motors and transmissions on eBay all the time, and not that I've purchased an entire engine I have had great luck with buying parts off it. Craigslist is more of a crap shoot, but you could look locally...if you are in a rust belt state you could probably find a donor truck with everything you need.
