Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
aftermarket heads
Old 12-22-2009, 11:31 AM
migamag's Avatar
migamag
migamag is offline
aftermarket heads
hello all,
my '00 lightning spit a spark plug sunday night and instead of fixing the ford head i was thinking of installing aftermarket heads. does anyone have any experience with Trick Flow heads? can anyone recommend a set of heads?
my truck has a Bassani exhaust and a K&N cold air kit. i don't plan on doing any other mods.
thanks in advance.
Old 12-22-2009, 11:52 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
JDM at www.teamjdm.com
Excellent, quality heads and cams. Call 'em up and tell them what you want.
Stewart
Old 12-22-2009, 04:55 PM
slammedi'am's Avatar
slammedi'am
slammedi'am is offline
I ve heard mixed reviews on the new Trick Flows.I like anything JDM sells..You can also look into Patriot heads.
Old 12-22-2009, 05:49 PM
Stewart_H's Avatar
Stewart_H
Has the quality of the Patriot heads gone up? It's been a couple years since I've been immersed in the L scene over at NLOC, SVT P, and L/Rodder, but Patriot developed a pretty bad rep for failed heads. Unless you're using them as bare cores and building them yourself, or having your builder put them together, I'd stay away from their completely built heads. Unless of course they've gotten better.
Stewart
Old 12-23-2009, 04:01 PM
slammedi'am
Theres quite a few peeps over on LR that uses them.I never heard anyone say anything bad about them while I have been on there and the other L boards
Old 12-23-2009, 10:38 PM
Stewart_H's Avatar
Stewart_H
Yeah, they had some pretty bad failures, and a couple near catastophic ones that almost took out some really high powered, built engines, if they hadn't been found by the owner.
I know a lot of guys took to using the bare heads and building them with the components they wanted, using the correct process to assemble them, to eliminate the problems that were cropping up.
Stewart
Old 12-24-2009, 11:56 AM
migamag's Avatar
migamag
migamag is offline
Stewart
are you talking about the Trick Flows or the Patriots?
Thanks for all the input, guys!
Old 12-24-2009, 12:10 PM
Stewart_H's Avatar
Stewart_H
See post #4.
Stewart
Old 12-27-2009, 07:58 AM
phil6608's Avatar
phil6608
phil6608 is offline
The only "aftermarket" heads are the Trick-flow heads.
All the others are ford factory castings.
Shop around for the best price but I wouldn't recommend the patriot heads even though they are the cheapest. lol
.: Johnny Lightning Performance
LFP Stage II Ported Heads Ford 5.4L SOHC [Stage2] - $1,649.95 : Lightning Force Performance
I run stage 3 from here! Total Engine Airflow Whoever you order from ,have them fix the plug threads! TEA welded up my plug holes ,re-drilled them and they have like 10 or more threads now
Fox Lake Power Products, intake manifolds, assembled shortblocks, modular shortblocks, CNC modular heads, P-51 installation, comp cams, crower, ferrea components 1999
Old 01-07-2010, 05:59 PM
migamag's Avatar
migamag
migamag is offline
thank you all again for the input.
i decided to stick with stock heads and sleeve every plug boss so i'd never have to worry about this again. my lightning's mill is currently on a stand having this done...decided to change the water pump while the motor was out (it's still running the original pump).
Old 04-21-2010, 11:57 AM
DREW148BHP's Avatar
DREW148BHP
DREW148BHP is offline
I have heard good things about the Patriot heads
Old 04-21-2010, 01:36 PM
Stewart_H's Avatar
Stewart_H
Do your research at NLOC and SVT Performance and you'll change your mind.
Stewart
Old 04-21-2010, 02:02 PM
DREW148BHP's Avatar
DREW148BHP
Anyone have any experience with these guys:
ModularHeadShop Modular Heads
Old 07-21-2010, 04:29 AM
basswave83's Avatar
basswave83
basswave83 is offline
Just had patriot heads put on my 01 lightning. The heads were bare, I just switched the parts from my old heads. Now I have no power. Boost will be around 10 psi but the truck does not increase speed and the rpm's are low. The mechanic can not find any vacuum leaks. There was a code that came up, when the check engine light came on, for excessive fuel and he fixed that but no change in the way it performs. Also, it sounds like there is air blowing through the vents but there isn't. As of right now, there is no engine codes coming up. Are these problems caused by the heads or something else?
DD31
03-24-2017 08:54 PM
2012 F250 6.2
2017+ Super Duty
02-01-2017 06:23 PM
Jeff53
07-25-2016 06:32 PM
norman2012
07-13-2016 11:57 PM
Powerbypressure
11-25-2006 01:05 AM
Quick Reply: aftermarket heads
