Differences between modern trucks and 30+ year trucks
I was a salesman for a Lincoln-Mercury Toyota dealership in the mid-70's. There were light years of quality and engineering differences between the two manufacturers then but Ford has closed the gap significantly since then. The not so bright idea Mercury Monarch comes to mind. The dealership had to realign the body work, and it was pre-EFI. Even the straight six ran horribly with the spaghetti bowl of vacuum lines in the new catalytic converter era. Plus 20% interest rate during the Carter administration did not help financing the cars.
that's nice but i will stick with the 30+ year old trucks . mine will out perform any modern truck in load an pulling power . plus if it gets scratched oh well . plus parts don't cost an arm an a leg for the older trucks. i also don't need a computer to fix the truck so you can keep the new piles of $60,000 junk!
hey road_warrior you will be the only one embarrassed when i drag your 2000 dodge around like the pile of junk it is lol as far as pulling power i won't even notice it back there !! dodge 2500 that's all you got, its only a 3/4ton. The truck i have can pull full size school buses with out there axles around very nicely she can haul over 5 tons of anything. she can tow over 10,000 pounds of trailers so your dodge isn't nothing. plus i only have to load the flatbed once then to unload i hit the switch and dump everything
I'm not saying the new trucks are total crap, because they're nice to drive and all, and I do like the modern Cummins, but there's just too much junk hanging on them for my tastes, and the cost is high. I want it simple and affordable.. My Cummins Bronco cost me about 5k to build in total. I could build TEN of my trucks for the price of a new diesel truck. It's entirely mechanical, even the automatic shifts without a computer. Cheap, simple and tough.
Actually, I will amend my earlier statement, I think new Obama Motors vehicles are in fact pretty crappy, especially with the maxi-pad Isuzu diesel in them. But the Dodge Cummins and the Ford 7.3s (Not a fan of 6.0s though) are excellent.
In terms of what you mentioned about stock vs stock; there wasn't any diesels available 30 years ago in pickups, so you can't compare a modern Dodge Cummins to anything from that era. But I'd take an old 390 big block with cast iron 4-speed transmission in an F250 ANY DAY over ANY new production gas truck. Good Lord, it's like comparing an anvil to a paper clip.
Ok my truck started life as a 1972 ford f-250 4x4 highboy. and now its the truck ford never built a 1972 f-350 4x4 high boy
here is the trailer that i tow
and here is the weight. need to add more the stuff inside .
here is the truck
one flat bed with dump
power steering conversion
one 390 bored 60 over with rv cam
duraspark conversion for the 390
pushes a hell of a lot of snow
one d 70 rear axle
ok there you all go thats my truck go ahead an rip it apart an laugh all you want but i know what she can do . an i put her together for about 5k . i did put disc brakes up front . 4speed with granny gear wouldn't trade that in for the world . when i would part out a rig i would cut the remains up an haul it to scrap on the bed .
here is the truck
one d 70 rear axle
