Need help with codes
This is what I'm getting. I need to know what i should do next.
KOEO
32 EVP circuit below minimum voltage of 0.24 volts.
84 X X EGR Vacuum Solenoid circuit failure.
85 X X Canister Purge Solenoid circuit failure.
<TABLE style="FONT-SIZE: 100%" border=1 cellSpacing=0 cellPadding=2 table><TBODY><TR><TD rowSpan=2>32</TD><TD><CENTER>X</CENTER></TD><TD> </TD><TD><CENTER>X</CENTER></TD><TD>EVP circuit below minimum voltage of 0.24 volts.</TD></TR></TBODY></TABLE><TABLE style="FONT-SIZE: 100%" border=1 cellSpacing=0 cellPadding=2 table><TBODY><TR><TD rowSpan=2>32</TD><TD><CENTER>X</CENTER></TD><TD> </TD><TD><CENTER>X</CENTER></TD><TD>EVP circuit below minimum voltage of 0.24 volts.</TD></TR></TBODY></TABLE><TABLE style="FONT-SIZE: 100%" border=1 cellSpacing=0 cellPadding=2 table><TBODY><TR><TD rowSpan=2>32</TD><TD><CENTER>X</CENTER></TD><TD> </TD><TD><CENTER>X</CENTER></TD><TD>EVP circuit below minimum voltage of 0.24 volts.</TD></TR></TBODY></TABLE>KOER
32 X X EVP circuit below minimum voltage of 0.24 volts.
41 X X No HEGO switching detected always lean (right side).
77 X System failed to recognize brief WOT during Dynamic Response Test (user error).
I understand I did something wrong on the 77. not sure what though. What should I be doing/replacing to fix these codes.
KOEO
