speedometer problem
Old Jun 15, 2010 | 01:57 PM
adpranger's Avatar
adpranger
speedometer problem
i replaced the abs/vss sensor and now when i hit 60 the speedometer starts moving back and forth then it eventualy stops working then the check engine light comes on and the o/d light starts flashing.
someone please help
Old Jun 15, 2010 | 03:45 PM
wtroger's Avatar
wtroger
Still sounds like loss of vss signal pull the codes and see what it is trying to tell you. You may have a bad connection or bad wire. Is this the same problem you had before you replaced the vss. if not maybe the new vss isn't any good
Old Jun 15, 2010 | 04:03 PM
mfp4073's Avatar
mfp4073
gotta give us some info, just saying a ranger and a problem does not narrow it down enough!
year, model, engine, trans, miles, etc!
