EGR Code?
Unless someone has done something to it, a '94 should have an EGR valve/system.
My code list indicates that a 335 can only be a KOEO code. Because KOEO codes are set with the engine off, they are almost always electrical -- in this case, a fault in the DPFE sensor circuit. As frequently as the DPFE sensors fail on these, I'd be tempted to make sure everything is plugged in, and then just replace the DPFE sensor if something wasn't unplugged.
