Octane NAvi vs Expedition
Straight from the 2006 Navigator owner's manual:
Octane recommendations
Your vehicle is designed to use “Premium” unleaded gasoline with an (R+M)/2 octane rating of 91 or higher for optimum performance. The use of gasolines with lower octane ratings may degrade performance. The use of gasolines labeled as “Premium” in high altitude areas that are sold with octane ratings of less than 91 is not recommended. Do not be concerned if your engine sometimes knocks lightly. However, if it knocks heavily under most driving conditions while you are using fuel with the recommended octane rating, see your authorized dealer to prevent any engine damage.
Straight from the 2006 Expedition owner's manual:
Your vehicle is designed to use “Regular” unleaded gasoline with pump (R+M)/2 octane rating of 87. We do not recommend the use of gasolines labeled as “Regular” that are sold with octane ratings of 86 or lower in high altitude areas. Do not be concerned if your engine sometimes knocks lightly. However, if it knocks heavily under most driving conditions while you are using fuel with the recommended octane rating, see your authorized dealer to prevent any engine damage.
In 2007, both the Expy and the Gator were specified to use 87 octane.
There were no compression or other engine changes between '06 and '07. In fact, the engine is still the same in '10.
So why does the '06 need premium while the '07 does not?
My guess is that Lincoln just forgot to update the Owners Manual from the previous generation 32V Intek motor. Finally, someone caught the typo.
BTW - My '01 AWD 32V Intek Gator would have left my '07 2WD 3V Gator in the dust (if I still had it), even on regular 'ole 87 octane pump gas.
This is just speculation on my part and another angle of it.
Maybe Ford found that running higher octane in the engine got it a slightly better fuel mileage rating for the EPA when they put it to the mileage tests. Just a thought. If they got only 10mpg on 87 octane but got 11mpg on 91 or better octane, maybe they then specified that in their owners manuals to satisfy the EPA controls over mileage.
2007 2WD Expy is rated at 12/18. 2WD Gator is 12/17 (6 spd auto in 2007).
So switching to reg gas in 2007 really did not hurt MPGs in the Gator.
So I am not sure this is the reason.
