Need help fast....
Old May 9, 2010 | 11:10 AM
devildog30188's Avatar
devildog30188
Exclamation Need help fast....
I've been fighting a losing battle to pass emissions recently and 'm running out of time, my 98 ranger 4 cylinder is throwing the P0401 Low EGR Flow code. I have replaced the EGR valve, the DPFE sensor, and spent hours with throttle body cleaner and a coat hanger trying to clean the flow tube running from the exhaust to the EGR valve. I'm running out of things to do, my only remaining ideas would be to replace the vacuum solenoid or the flow tube. Any ideas?
Old May 10, 2010 | 06:42 AM
pawpaw's Avatar
pawpaw
The EVR, it's vacuum lines & electrical connections probably belong on your suspect list for a P0401 code.
To do a quick function test on it, pull it's vacuum line connection at the EGR valve & do a blow back test. You should have resistance to the blow back, if not the EVR valve or the vacuum line back to it is likely leaking & that'll cause a weak vacuum control signal to the EGR valve & it won't properly open & can cause a P0401 code.
Also if the EVR's electrical connection is bad, it's operating electrical signal from the computer could be corrupt & cause it to not function right.
So if the blow back check seems ok, check it's electrical connector for corrosion, loose pins or sockets, damaged wiring & B+ operating voltage at KOEO.
Let us know what you find.
cixelsyd
1997 - 2003 F150
Jul 12, 2013 08:46 AM
bruening675
1997 - 2003 F150
Jun 6, 2010 07:40 AM
BCHauler
Oct 2, 2008 04:27 PM
Brope
1997 - 2003 F150
19
Aug 15, 2006 03:45 AM
jad
May 15, 2005 08:30 PM
