1994 f150 weird noise driv. sd wheel well
i am getting a weird "tinking" noise coming from the drivers side front wheel. it sounds like metal on metal clinking, almost like crystal clinking together. ive looked under there and didnt see anything loose so im not sure where it could be coming from. just installed new shocks but everything is tight ANY IDEAS?
do you have the screw-on metal hub caps? i had an 86 bronco with those, and they would make a tink tink tink noise if they came loose..could also be the wheel bearing, anti-rattle clip for the brake pads may have fallen off, did you accidently bend the splash guard for the brake rotor when installing the shocks.. did that by accident on my truck and it made a light scraping noise..
henry bigham
10-09-2015 11:11 AM
NativeDescent
04-25-2015 11:47 AM
Grandpas1978f250
02-12-2014 09:37 AM
the_auto_tech
12-03-2013 04:13 AM
mudrat025
35
09-24-2013 01:35 AM
