Engine fan trigger
Old May 5, 2010 | 11:18 AM
utjer's Avatar
utjer
Engine fan trigger
What temp triggers the engine fan to kick on? Is it based off of ECT or EOT?
Old May 5, 2010 | 11:58 AM
liv's Avatar
liv
It's ECT. I think it's 220?
Old May 5, 2010 | 12:41 PM
Cowboy65's Avatar
Cowboy65
Somewhere around 210 - 220, although temperature is not the only parameter used to determine when the fan should be running. I saved the following from a previous post, however I don't have a link. I seem to recall that it was posted by bismic but I could be wrong.
Engine temperature is not the only parameter that the PCM monitors to determine cooling fan operation. This is the reason that you will see some variation in engine temperature as it correlates to fan operation. The operation/description of the FSS (Fan Speed Sensor) from the PC/ED manual has a fairly good explanation as to how the system "thinks". This is not your traditional engine hits temp X and the fan clutch locks up. The fan speed sensor is a Hall-Effect sensor integral to the vistronic drive fan (VDF). The powertrain control module (PCM) will monitor the sensor input and control the VDF speed based upon engine coolant temperature (ECT), transmission fluid temperature (TFT) and intake air temperature (IAT) requirements. When an increase in fan speed for vehicle cooling is requested, the PCM will monitor the FSS signal and output the required pulse width modulated (PWM) signal to a fluid port valve within the VDF.
Old May 5, 2010 | 12:49 PM
utjer's Avatar
utjer
Thanks for the info. This explains alot. I did some serious mountain towing this weekend on a trip to moab, ut. I hit 220 ECT once or twice for not very long pulling some big grades. The tranny temp stayed between 160-165 the entire time. Outside air temp was 35-45 degrees depending on elevation. The fan never kicked on so this is why I asked the question.
Old May 5, 2010 | 02:12 PM
janton01's Avatar
janton01
Not sure if my 04 is any different but when my oil cooler was plugged with sand the engine fan would run constantly when I was pulling the boat but not when unloaded. Now with the new cooler and egr it very rarely runs at all. When the cooler was blocked it also puked from the degas but that has also stopped. I was told the the eot could also cause the fan to run.
ExPACamper
Nov 1, 2016 01:51 PM
cixelsyd
1997 - 2003 F150
Oct 20, 2016 10:31 PM
F-250 restorer
21
May 1, 2015 10:39 PM
tcatrider_99
Aug 28, 2014 01:18 PM
vatreefarmer
Jun 1, 2014 09:14 AM
