Tranny ID
Tranny ID
I have a 1978 Ford F150 Custom w/ a 4 speed overdrive tranny. You lift up, shift over and up to shift into reverse. I crawled under it and there is linkage on the outside of the tranny, driver's side if I remember correctly.
What transmission is this? Designation number I mean. If it is what I think it is, from searching on here, its the weaky sister tranny. Please tell me it isn't!
Also, is there a drain and fill on this Tranny so I can change the gear oil?
Thanks alot folks! Really enjoying the site and all the great information on here!
The external linkage "SMOD" variant of the 4 speed OD would be a bit stronger than the aluminum cased units. OD is weak, tiny little gear.
Ratios suck, 2nd to 3rd is the Grand Canyon.
There was a drain and fill on mine.
Pics info at these two sites.
Domestic Truck Tranny Guide
Toploader 4 Speed Transmissions
Toploader Imposters
Toploader Imposters
Ford 'RUG' TS-OD Single Rail 4 Speed Overdrive. A "weak sister" of a transmission originally designed for and installed in Passenger Cars (Granada/Fairmont/Zephyr).
Ford installed this transmission in F100/150's & Econolines beginning in 1978 to improve fuel economy.
One speed shift, you can kiss the little darlin' good bye.
I can personally attest to the fact that the iron cased 4 speed OD will handle dumped clutches and speed shifts at full throttle (well, as fast a speed shift as the "long travel" linkage will allow) behind a 300 in a 4000lb van. And the squeeling bearing noise got no worse....
The aluminum case...not so much I guess....
Uphill with curves and a load on board with a 40 mph speed limit will drive you nuts though...
ymmv.
This bushing could take no abuse...at all. Basically it could fall apart when you looked at it. I sold soooo many, I memorized the part number decades ago.
D9BZ7K453A / It's as obsolete as the dodo bird. One FTE member looked for one for over a year...until I got involved.
As of right now...there are exactly two available, one at a dealer, one at an obsolete parts vendor.
So...go right on ahead, speed shift this puppy...it won't be very long before you need one a these little charmers.
