Performance Chips
Old Apr 30, 2010 | 06:41 AM
srb1194's Avatar
srb1194
Question Performance Chips
Does anyone have any recommendations on which ones are the best? I've looked at Performance Chips Direct & Horsepower Chips. Let me know your thoughts on these.
Thanks.
Old Apr 30, 2010 | 08:40 AM
shotgunz's Avatar
shotgunz
https://www.ford-trucks.com/forums/9...formance+chips
And I'm sure there are more.
Ford Truck Enthusiasts Forums - Search Results
Spend as much time as you want, but why search for junk?
Old Apr 30, 2010 | 07:52 PM
819jack's Avatar
819jack
I have the edge evolution comes with a mounting pod tha fits to your dash it has 3 preprogram levels and options to alter many parametters also scan tool for engine troubles check them out on the net I love mine .
Old Apr 30, 2010 | 08:27 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
don't get a chip. prior to 1996 & OBD-II, you had to chip your PCM to get performance goodies for your EFI vehicle.
1997+ vehicles use the OBD-II system and handheld programmers to change the PCM parameters.
most performance chips are nothing but a resistor in some fancy packaging. the resistor changes the voltage from the IAT to the PCM. This tells the PCM the motor/air charge is still cold and the motor dumps more gas to heat things up.
Get an Edge/Gryphon/SCT/Diablo. They are all reputable companies.
Old Apr 30, 2010 | 08:43 PM
USAF FordGuy's Avatar
USAF FordGuy
off topic but kinda interesting, had a 1995 thunderbird 4.6, it was OBDII, wierd huh? also it had a.... superchips performance chip that plugged into the computer!
Old Apr 30, 2010 | 09:03 PM
1bad67sbf's Avatar
1bad67sbf
like 819jack the edge evolution is the way to go. it not only makes the trans way better but it makes the whole truck so much more fun. it is one of the best mods ive done!!!!!
Old Apr 30, 2010 | 09:04 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
1996 was the cut-off year for OBD-II. starting in 1996 all vehicles are/were federally mandated to run OBD-II...just like all 2007+ vehicles must now have the tire pressure crap (TPMS)
prior to that, most companies used the OBD-I system. The higher end cars had OBD-II though since they usually had more complex fuel managment systems and OBD-I sucks some major behind.
Yeah, I had a buddy running a F-350 diesel who had one of those Superchip chips. Those things are legit. But if you roam around eBay, you'll see a bunch of sellers with "Performance Chips"...and they aren't the same
Old Apr 30, 2010 | 09:05 PM
USAF FordGuy
yea like you said they're just a resistor, should see what one of those do to a 93 Taurus GL!!! Hillarious
Old Apr 30, 2010 | 09:07 PM
1bad67sbf's Avatar
1bad67sbf
the tire pressure units are a pain can i turn them off due to aftermarket wheels
Old Apr 30, 2010 | 09:09 PM
USAF FordGuy
I dont think so, pretty sure that's a no, and also quite controvercial in another thread
Old Apr 30, 2010 | 09:13 PM
1bad67sbf's Avatar
1bad67sbf
yeah i read the thread about lazy people not checking tire press, i paid alot off $ for my tires and check them alot because i dont plan on new tires for a while
Old Apr 30, 2010 | 09:14 PM
USAF FordGuy
yea, its not that hard to check. but i dont think they can be turned off
Old Apr 30, 2010 | 09:21 PM
1bad67sbf's Avatar
1bad67sbf
usafguy how is the 5.4 treating you mine to be honest is a b***h but has fair power and sounds bad ***!! how many miles?
Old Apr 30, 2010 | 09:23 PM
srb1194's Avatar
srb1194
Thanks for the tip. I thought the chip sounded too good to be true. I'm going to research the Edge Evolution and see what I think.
Thanks.
USAF FordGuy
ive only had it a week, gotta say I love it! 54k miles and I got a waranty up to 100k on it. But Im waiting on getting the radiator replaced...pushed her alil hard offroad last weekend, but its covered under waranty, they just dont hve a radiator in stock
