Another no start thread...
Old Apr 28, 2010 | 09:20 AM
wla6518's Avatar
wla6518
Hey yall, having a no start issue that I have not seen on here before.
Here is a little history: Got home from a trip Sunday, shut the truck off and unloaded. Went back out to Monday morning and it was a no start first try (didnt even turn the starter), then cranked right up on the 2nd attempt. Cranked fine again when i headed home.
Next morning got in the truck and again a no start. Didnt have time to mess with it, so I hopped in the jeep i just towed back and went to work.
Both Batteries are new
one alternator is less than a year old
Here is everything I checked / tried last night:
- cleaned terminals
- cleaned contacts on starter
- cleaned ground contact on motor
- checked all fuses
- cleaned contacts on clutch switch
- checked connections at ignition switch
- jumped batteries from wifes truck
- lightly tapped starter with a hammer while Jenn attempted to start the truck for me
is it possible for the starter to just crap out like that?
is there a seperate starter solinoid that I am not aware of? (Like the older ford gas motors)
could it be the circular contact ring on the steering wheel? (cant think of the name off hand)
Is there any reason I should suspect the chip?
I have had a few instances where the chip will put itself in the no start mode and run the fuel dry after it has been put into a tune, anyone else experienced this?
I figure tonight I will take the batteries, both alternators and the starter over to have them tested...should be fun
Thanks in advance for all of yalls help. I know yall will walk me through this!
Old Apr 28, 2010 | 10:22 AM
Ponyboychris's Avatar
Ponyboychris
I would start with removing the chip just to take care of that variable. Yes, the cable can come loose and cause intermittent no-start issues.
Old Apr 28, 2010 | 10:26 AM
wla6518's Avatar
wla6518
will it show that it is in a tune even if the cable comes loose?
I will definitely try this first, just wonderin
Old Apr 28, 2010 | 10:35 AM
DieselCamper01's Avatar
DieselCamper01
I don't think the tuner will display anything if loose but I could be wrong. I don't have the truck at work today to verify that though.
Old Apr 28, 2010 | 11:21 AM
serviceguy's Avatar
serviceguy
have you checked to see if you are getting voltage to the starter? if not it could be your neutral safety switch or solenoid. If you have good power to the starter motor it is most likely the starter.
Old Apr 28, 2010 | 11:23 AM
wla6518's Avatar
wla6518
will check that as well this afternoon.
im assuming the key needs to be in the on position to check?
is there any danger in arc'ing the solenoid to check that as well?
Old May 4, 2010 | 03:52 PM
wla6518's Avatar
wla6518
Well, after testing everything on the truck the problem is solved.
For some reason I was under the impression that the starter solenoid was on the starter plunger on this truck. Guess I thought the diesel would be different.
Turns out there is a solenoid mounted on the passenger side front fender.
I do now have very clean contacts and block ground, as well as brand new body grounds, a clean clutch switch, a few new fuses, a new 3rd brake bulb, and a much better understanding of the starting system on these trucks.
Thanks again for all of yalls help with this.
98F150on33s
1997 - 2003 F150
Nov 26, 2014 11:28 AM
Factola72
24
Apr 7, 2014 06:23 PM
Cory74700
Sep 16, 2013 11:37 PM
GonzoCSU
Feb 3, 2010 08:54 AM
pekkah
21
Dec 18, 2007 09:06 AM
