1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
REPACK REAR WHEEL BEARINGS?
Old 03-29-2010, 08:11 AM
stana1's Avatar
stana1
stana1 is offline
Any suggestions as to when to repack the rear wheel bearings on a 2001 F-250 SRW with 121,000 miles? Thanks.
Old 03-29-2010, 03:46 PM
barr75's Avatar
barr75
barr75 is offline
THEY ARE LUBED WITH THE AXLE GREASE. NO NEED TO REPACK. IF YOU TAKE THE HUB OFF FOR SERVICE, PACK WITH A LITTLE GREASE SO THEY WONT RUN DRY UNTILL THE GEAR LUBE GETS TO THEM. JUST MAKE SURE THE GEAR LUBE IS FULL AND THE REAR END COVER IS NOT RUSTED OFF YET.
Old 03-30-2010, 07:49 AM
stana1's Avatar
stana1
stana1 is offline
Thanks for the info. Guess that's why I couldn't find anything doing a search.
J ballan
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
21
07-20-2017 11:28 AM
chillman88
10-26-2016 07:45 PM
airsoft1779
28
12-12-2012 10:09 PM
run6.0run
02-11-2012 09:05 PM
99F150
Oil & Lubrication
08-16-2009 07:10 AM
Quick Reply: REPACK REAR WHEEL BEARINGS?
