flathead lifters pitted
Old 03-20-2010, 08:04 PM
tony1947's Avatar
tony1947
tony1947 is offline
Question flathead lifters pitted
I just started tearing down my 52 V8 , it looks like it was a real oil burner , most of the valves were not sealing good and oil/sludge was knee deep under the intake manifold . I got the valve assemblies all out , good fun there! And then when I pulled out the lifters 4 of them were badly pitted from the top to were they come up to open the valve . I didn't see any water in there to rust them ,they look clean but pitted . What could cause this? Is it something to worry about? Some of the valve guide were worn , I could wiggle the valves a bit. Engine was never stuck like most are ,turned over ok, just some of the vaves were stuck ,PB blaster ,time and a rubber hammer loosen them up fine. tony
Old 03-20-2010, 11:16 PM
fixnair's Avatar
fixnair
fixnair is offline
Pitting of the lifter cam face is usually caused by acidic oil. Previous owner probably did not change oil often enough.
Fords&Farmalls
27
04-11-2022 09:26 PM
MattMac
07-10-2017 03:12 PM
C_thetroll
26
08-18-2016 04:49 PM
GSlahor
08-19-2015 09:36 AM
helifixer
Arizona Chapter
02-24-2009 08:07 PM
Quick Reply: flathead lifters pitted
