fipl sensor question
Old Mar 7, 2010 | 09:10 PM
rupejosh's Avatar
rupejosh
ok well i went and checked my sensor today and it was way outta adjustment its suppose to be 1.0 - 4.3ish at w.o.t.and i cant get it close to 4.3 i could only get it to 1.0 - 3.6 at W.O.T. any ideas on that guys?im not too good with trannys so i figured i would ask a few of you all that have dealt with theses e40d's more than me
Old Mar 7, 2010 | 09:53 PM
starmilt's Avatar
starmilt
It is easy on mine especially if I use the clutch.
Old Mar 7, 2010 | 11:02 PM
rupejosh's Avatar
rupejosh
oh i never thought of that now if i can find that stinkin' clutch pedal
Old Mar 7, 2010 | 11:24 PM
starmilt's Avatar
starmilt
It's the one on the left.lol
Old Mar 7, 2010 | 11:45 PM
crazymike's Avatar
crazymike
the fipl sensor is 1.0v at idle setting witch is right for normal operation, i replaced my own recently. i got a cheaper one from autozone cause i didn't wanna pay the ford price (they got enough of my money on that day"
i couldnt get my cheap senser to go above 3.6v at wot when it was adjusted to 1.0v at idle.
i read that you could increase the idle setting a little (mine went to 1.35 or thereabouts)
and now it shifts a bit later and by a bit i mean at 2200 rpm instead of 1250.
i like it a lot better for driving with a load or towing.
i've been working with the cheap sensor for about a month and a half now so its working so far, ill probably get an actual ford one later maybe after my first paycheck witht he new job
so basically as far as i know it should be allright, but you may look into a replacement if you want to go from 1.0v all the way to 4.6v
Old Mar 8, 2010 | 12:03 AM
rodneywar's Avatar
rodneywar
not to jack the thread but how do you check it which prongs do you connect the volt meter to?
Old Mar 8, 2010 | 01:20 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
remember though,the sooner you can get into your next higher gear(without lugging.but the auto will shift way before the idi could even think about that anyway) the better your fuel mileage is going to be.
im telling ya guys.start out slow and easy,and let her get into the gears quick.
im getting 20+ mpg like this.(roughly.based on a couple gals estimate at a time.)
you guys who need to haul ars 70+ and get there like no tomorrow.......well big oil co's love ya lol.
thats one of the cool things i noticed right off about this combo.is she would go right into the next gear quick and low mph's.
the engines torquey and can handle it.if your hauling,and you want to make her stay put,why not use the shifter?
if you shifts are mushy and your hoping to firm them up by going to higher rpm shift points,i see.but man,shift kits dont cost much.
Old Mar 8, 2010 | 01:27 AM
starmilt's Avatar
starmilt
LOL If I go to town it is usually a 200 mile trip, I don't think I will be going to slow, in fact if I was to try to run 55 or 60 it would be downright dangerous.
Old Mar 8, 2010 | 01:28 AM
rupejosh's Avatar
rupejosh
no big deal with jacking the thread.the fipl has 3 wires the center one is green and thats the one you want to use
Old Mar 8, 2010 | 01:32 AM
starmilt's Avatar
starmilt
Josh I may have traded for one with an E40D today, not sure what for. The last time I seen it and the last time it was driven it shifted real hard, is this a fipl problem or more serious.
Old Mar 8, 2010 | 01:42 AM
rupejosh's Avatar
rupejosh
it shifts hard?it may have a shift kit.i would much rather have mine shift like that.i think if the fipl was outta wack it would be sloppier shifting....but i may be wrong
im still looking for that dang clutch pedal....lol
Old Mar 8, 2010 | 01:53 AM
starmilt's Avatar
starmilt
I'm talking it shifts hard not shift kit hard but something hard ,jerk the truck hard.
Old Mar 8, 2010 | 01:58 AM
rupejosh's Avatar
rupejosh
my brother inlaws e40d is like that it slams into gear like someone hit ya from behind hard.lol
Old Mar 8, 2010 | 02:26 AM
starmilt's Avatar
starmilt
That is how this one is, how ever sometimes it will shift right, but a lot of the time it slams you. lol
Old Mar 8, 2010 | 02:30 AM
rupejosh's Avatar
rupejosh
i would say tach sensor can cause that
