spring question
Old Mar 7, 2010 | 02:51 PM
nfld's Avatar
nfld
spring question
I changed my front springs last week along with shocks.I put 450 springs and kyb shocks and tweeked my steering box.Now the issue is that the X is low on the back.I assume that if the front springs are soft so are the rears.So should I change the rears or just add spacers.......Thanks.
Old Mar 7, 2010 | 03:01 PM
fatdan460's Avatar
fatdan460
if you tow with it i'd replace the springs, but the fronts might settle a little after some miles so you might wanna wait a while before you decide
Old Mar 7, 2010 | 03:15 PM
nfld's Avatar
nfld
The only thing I tow are 2 fat golden retrievers that would live in the back if I let them.Fat dan The taper blocks are they available in different heights.My originals are 2.250 and if I want to level the truck I need 4 inch blocks
Old Mar 7, 2010 | 03:31 PM
fatdan460's Avatar
fatdan460
i'm sure if you look at some suspension companies web sites you could probably find what your looking for, just try to stay away from stacked blocks or spacer blocks they are junk. find one solid block
Old Mar 7, 2010 | 03:41 PM
Hollywood703's Avatar
Hollywood703
there are taper blocks available to level the truck, not sure specifically about 4" but i believe there are 5.5's. and ford has stock blocks:
Left side 3.5" tapered block: Part #F81Z-5598-FA
Right side 3.5" tapered block Part #F81Z-5598-GA
Old Mar 7, 2010 | 05:29 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
after i put X code springs(which gave almost 3" of lift over stock) in i had to add the tapered factoy f-350 blocks to level it out.
Old Mar 7, 2010 | 06:46 PM
nfld's Avatar
nfld
alaska have you got a part number???????????? thanks
Old Mar 7, 2010 | 06:56 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
should be the part numbers above my last post. i dont know what the part numbers on the u bolts were. if you search you will find all the info you need, i searched for a few months before doing my swaps(front/rear)
Old Mar 7, 2010 | 07:08 PM
nfld's Avatar
nfld
I checked out yor MPG think I am in the same boat...Thanks for the info...
Old Mar 8, 2010 | 06:02 AM
Skip1970's Avatar
Skip1970
code x springs?
Old Mar 8, 2010 | 06:28 AM
Hollywood703
Code X springs are the HD springs put in with the plow package. They are quite stiff, but gives a very sturdy front end, they are also helpful when adding a HD bumper like a ranch hand or Warn Bumper.
Old Mar 8, 2010 | 08:03 PM
nfld's Avatar
nfld
I think I will go with new springs and be done with it.Thanks for the input all.
lakewood
13
Mar 4, 2013 06:30 PM
PStruwing
Oct 31, 2012 02:45 PM
cana55
1947 and Older Ford Trucks
28
May 16, 2011 08:56 AM
Scratch
Apr 9, 2005 04:05 PM
