Help with year.....
Old 03-06-2010, 02:59 AM
KiwiFord's Avatar
KiwiFord
KiwiFord is offline
Help with year.....
I have been told my F150 is a 1977, but there are a few things that point to it being a 1966....can anyone tell me off the following numbers:
7A86G130801084908 or F14SC084908, I got these off the NZ rego form, if they are wrong, I will go look at the ID tag.
Cheers, Shane
Old 03-06-2010, 04:25 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
7A86G130801084908 or F14SCO84908, I got these off the NZ rego form, if they are wrong, I will go look at the ID tag.
Cheers, Shane
F14 = F150 4WD Pickup
S = 400 2V
C = Oakville, Ontario Canada Assembly Plant
O84908 = 1977 Numerical Sequence of Assembly (Serial Number)
Old 03-06-2010, 07:39 AM
79 F100 Stepside's Avatar
79 F100 Stepside
79 F100 Stepside is offline
Bill, that's good work, can I get my VIN broke down like that?
Old 03-06-2010, 07:57 AM
NumberDummy
Sure, and post all the codes from the Warranty Plate. I'll decode all of that jazz, too.
Old 03-06-2010, 09:12 AM
79 F100 Stepside
VIN Numbers and Codes
Not too sure what all this is but here goes
VIN Plate (Metal on Driver's Door)
F10BLDJ5021
WB 117
Color V
Type/GVW F101
Body AT3
Trans C
Axil M3
1979 42
Other Info (Sticker on Driver's Door Jamb)
Only listing what is not obvious
After the VIN there is a number F0243
Type: Truck T0744
Says Truck was mfg'd 11/78
Thanks
Old 03-06-2010, 09:45 AM
first today's Avatar
first today
first today is offline
Cheers, Shane
There are more than a few things that differentiate a 66 from a 77. They are complete different bodies. Did you make a typo and mean 76?
Old 03-06-2010, 10:57 AM
460/5's Avatar
460/5
460/5 is offline
Zombie Survivalist
same question as first today.
Old 03-06-2010, 11:20 AM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
F10BLDJ5021
WB 117
Color V
Type/GVW F101
Body AT3
Trans C
Axil M3
1979 42
Type: Truck T0744
F10 - F100 2WD
B - 300 1v
L - Michigan truck plant
DJ5021 - November 1978 sequential build
117 - 117 inch wheel base (regular cab, short bed)
V - Medium Chestnut Metallic
F101 - F100 2WD, 4800 lbs GVW
AT3 - AT = Sand all vinyl. 3 = Custom with Flareside box.
C - 3 speed manual tranny, Ford 3.03 AKA "Three on Tree".
M3? This isn't valid - please check again.
1979 - model year
42 - Cleveland, Ohio district sales office
Old 03-06-2010, 01:24 PM
NumberDummy
Originally Posted by Jermafenser
DJ5021 -1979, November 1978 sequential build
AXLE code: M3 might be H3 = Ford 9" / 2.75-1 / Limited Slip / 3750 lb. Rear Axle Capacity.
Old 03-07-2010, 01:35 AM
KiwiFord's Avatar
KiwiFord
KiwiFord is offline
Thanks Bill
Hi Bill, and thanks for that....I can't help but be dissapointed that it is Canadian.....but them's the breaks.
Yeah, I had a typo, I meant 1977, or 1976, not 1966. Bill answered that for me!!
Shane
Old 03-07-2010, 03:58 AM
NumberDummy
Shane
Being assembled in Canada does not mean it was only sold in Canada.
Most 1965/72 and all 1973/79 Crew Cabs were assembled in Canada, most were sold in the US of A.
I've decoded VIN's of Canadian assembled trucks, but...by their DSO codes, these were ordered from Atlanta GA and Pittsburgh PA.
Look on the Warranty Plate for the DSO code, post what it is.
Old 03-07-2010, 06:40 AM
79 F100 Stepside
Is the white sticker on the door jamb what you refer to as the "Warranty Plate"? And yes the axil code was H3.
Thanks for your help.
Tom
Old 03-07-2010, 06:58 AM
79 F100 Stepside
F10 - F100 2WD
B - 300 1v
1979 - model year
Do you know what city the Michigan Truck Plant is in? I could not find the Medium Chestnut Metallic on the Ford Truck Color list. Would the interior paint have been the same color? I need to restore the dash to the original color. After looking again the Axil Code is H3. And I guess Flareside = Stepside?
Thanks for the help.
Tom
Old 03-07-2010, 07:02 AM
79 F100 Stepside
Cheers, Shane
Sorry for Hijacking your thread.
Tom
Old 03-07-2010, 07:27 AM
NumberDummy
It was in Dearborn (The Rouge). Where it is today, I dunno, as Ford built a new Michigan plant several years ago.
What Ford Truck Color list would that be?
It's listed in the 1973/79 Ford Light Truck Parts Catalog and in the 1973/79 Ford Passenger Car Parts Catalog.
The BODY code is AT3: A = Upholstery color = Sand all Vinyl // T = Dash color = Sand // 3 = Custom, with FLARESIDE box.
And I guess Flareside = Stepside NOT! A Stepside is a Chevrolet.
COLOR code V = Medium Chestnut Metallic (Ford basic part number 5144) was also used on 1973/79 Passenger Cars with a COLOR code of 5M
The metal Warranty Plate is riveted on the left door face below the latch.
The white Safety Standard's Certification Label is glued onto the door face or glued onto the B pillar, below the striker plate.
Quick Reply: Help with year.....
