Guages vs. Digital Monitors
Problem with digital is you actually have to read them. An analog gauge you just glance over and you see where the needle is at. .. you don't have to focus on them. After a while when you get used to typical numbers. . . you arrange the gauges so the needles point UP when they are normal. . . then its real easy to see when something is outta wack. A needle also give you the ability to see trends easier. . . example. . . when EGT is rising. . you can see how quickly its rising by the rate of the needle. . . try doing that with four numbers!
Timmy
Timmy
My general rule-of-thumb for gauges is that if it changes fairly quickly over a relatively broad span (Boost, EGT, RPM, etc), or has a range/redline, then it should be an analog gauge. If it changes slowly or has a fairly tight nominal range (EOT, voltage, etc), then digital is ok to save dash real estate - esp if you can add a redline warning.
I run analog EGT, Boost, and a Terminator/AeroForce scan gauge on the A-pillar, with a plan for an analog fuel pressure and analog airbag pressures when I put Clay's new 650 dash in (now that we can work w/ the ZF-6!).
I have a Quadzilla with a chip package. the chip is a waist cause it actually screwed up my readings while on the throttle. but the guage part lets me have 4 readings of my choice (coolant,Boost, Tranni temp and EGT's). I am on my second one cause one of the buttons when bad and I couldn't scroll to change anything (warranty), but really once its set I have not touched it for a while.
its ok for guages, but if I did it over again I would go with regular gauges, but its just my choice. for what i does it works for me.
also along with my 4 readings on my pillar I also have three anolog type under the cubby for my in-bed tank fuel level and an extra boost cause I got one gauge for free and a PSI for my VO psi.
between my two boost readings one digital and one anolog there is about a 2-3 difference on psi. but nothing really that big.
This is something that I have been struggling with here lately. Until recently my mind was made up to get gauges. Then I started to read threads describing smog/emissions testing for diesels, and how some mods won't pass. In this case the boost probe and where and how it is attached. It is starting in California, but believe me as with all trends it starts here and migrates eastward. Some day we all be affected. So now I'm thinking digital, maybe once the demand rises the quality/effectiveness will increase. Just my flow of thoughts....
How can the quality improve?
Don't listen to what CSIPSD says, he doesn't like having any extra gauges in his truck at all
I am californian by birth and grew up there, I can see some a hole at an emission testing site failing you because you tapped in to the intake for a boost reading and it doesn't have a CARB number on the plastic flexi hose. They get all kinds of weird about stuff they don't have any business looking at.
Sorry SuperDuty4x4.. I was talking in the line of intake modifications. Clem1226 knows what I'm talking about...here in Cali folks can be real strict and by the book. If it don't have a CARB sticker it will fail. I went through this with a modified Mustang that has a super charger...the guys at the testing site went through it all and checked references on the CARB stickers..PITA I must say...if everything is up to snuff no problems other than the time and the questions asked by the tech.
#28
#29
