Loss of power
Loss of power
I have a 2.9 6 cilinder bronco II and i resently moved to montana, this winter i was starting it just about every day(it was sitting cause it needed new drive shaft) and when i finally got the drive shaft, i started it and there was a huge loss of power, it wont even rev up to 2000 RPM and wont go over 10-15 mph.
i have checked spark plugs and they are all good, and i have checked everything i know how. i let it sit for about 3 months before i was able to fix it, and at first i thought there was water in the gas, so i ran through all the gas and then put good gas in and nothing changed, then i changed the fuel filter, but had to red-neck rig it to make it fit in there. still nothing happened, i do have fuel pressure but maybe just not enough. any ideas of what i could check or do??
on
1 Post
Sounds stupid, but I would check the exhaust for blockage (like field mice and such). You'd be surprised what might 'accumulate' with a vehicle sitting. The water is still a possiblity. Did you run HEET or any kind of water displacement additive through it? Did you try draining the entire tank? Did you check fuel delivery pressure with a gauge? Did you check all your vacuum lines for leaks? Only other possibilities would be revealed by pulling diagnostic codes..... other than something to do with the ignition (bad pickup/module/coil/wires/etc). Gotta be something....
on
1 Post
If you're handy with a cheap pipe bender and mig, you can probably make your own converter test pipe and see if the converter is the cause of your problems. Otherwise, you might be able to talk a muffler shop into making a test pipe for you - of course, they will also want to install your new cat and charge you a pretty penny for it should that be the problem... but you can install one yourself fairly easily and avoid the expense.
