cold air intake
#31
#33
warm air has less oxygen than cold for a given volume .. your engine runs on oxygen (not air) and fuel .. (this is the whole idea behind 'cold air intake')
if you intake less cold air you can get the same hp/torque/MPG as you can intaking more warm air ..
kinda like I like my women to be low maintenance .. those intakes may be pretty and look good in front of a crowd but I'll take the cold air and low maintenance filter .. I just toss it out and drop in a new one .. no cleaning, drying, oiling, or worrying about over oiling and trashing any sensors .. and mine will perform just as good ..
but, you can decide what you like to do to your motor ..
#34
I'm sure you all have seen this, and I know that I've posted it before, but here we go. It's for a 460, it shows temperature change, mpg change, and hp/tq change.
Intake Temperature Comparison
Air Cleaner Performance Comparison
#35
I dunno , but those look more like ads for K&N .. ie: the guy selling you something (even if it's the mag that sells ads for the product) has everything to gain by making that product look good ..
also, on Intake Temperature Comparison check the 'note' at the bottom .. +1%HP for every -10*F .. so if your putting out (for easy math) 100 HP , you get 1 HP for every -10*F ..
and on Air Cleaner Performance Comparison the 'optimum configuration' is (surprise) a K&N filter (is this an advertisement?) and the stock air box thermally wrapped (to keep the intake air colder) ..
.. advertisement or real world? .. not really sure .. but they agree with the benefits of cooler air and the stock box ..
edit:
I wonder how (on Air Cleaner Performance Comparison) going from 206 HP stock to 211 HP w/ K&N in the 'optimum configuration' is -4% in HP ? .. (I think some of them numbers is bogus )
edit:
#36
and on Air Cleaner Performance Comparison the 'optimum configuration' is (surprise) a K&N filter (is this an advertisement?) and the stock air box AND thermally wrapped (to keep the air colder) ..
I don't think they were implying that your results would vary if you insulated your air box and used a paper filter.
#39
I would like to know why in Fords infinite wisdom they saddled the 302/351 with the different/inferior intake tube in the first place?......After all Ford is famous for using the same parts for whole ranges of models to save money, why a different part when the 300/460 part serves the best for all?
#40
we're looking for 'better' .. and will make the necessary 'adjustments' to get it ..
#41
I wonder if it could be related to Helmholtz resonance. It seems unlikely, since this is all taking place before the filter, but the 302 351 both have shorter strokes than the 300 & 460.
If they took the time to engineer and produce two different pieces, there had to be a benefit to the company (higher profits/better fleet mpg) greater than the cost to implement 2 designs.
#43
Corporate=idiot.
What is also interesting when comparing these two factory intakes-the 5.0/5.8 has a restriction in the intake tube right as it goes into the air cleaner housing.This restriction makes the tube cross section about half of what the rest of the tube diameter is. Seems unnecessary-perhaps works as a intake noise suppressor.
I too, wonder why Henry made two intake tubes. One good thing about the 5.0/5.8 tube is that it is higher off of the ground and would be better when going thru high water or when entering a body of water at a higher than reasonable speed when driving offroad.
The performance differences between these tubes are most noticeable when driving in cold weather.
And the 7.5 intake tube sure makes it easier to work in the engine compartment. Especially when installing the accessory drive belt. And cleans up the engine compartment visually.
#45
