You can dissasemble the dash cluster and use the middle part from the lightning and the rest of the diesel parts and it should work, but a 94 wont work with your 96.
they changed them about every 2 years.
try and find a 96 if you can.
Just remember, there is no way for you to swap your milage deal over.
if you have an auto, try and find an auto cluster as well, less of a pain to get that wire hooked up for the shifter.
ok thanks that's what I thought. I thought any gauge cluster from a 96 F-series with tach would work. I know the tach is different but the Amp/ Fuel and Oil/water and Speedo should all be the same
