Sponsored by: Auxito
Check Engine light & codes
Old Jan 20, 2003 | 08:19 AM
Rhoid's Avatar
Rhoid
Recently had the "check engine" light come on. Suspect a pollution control issue but do not have the service manual (97 4.6L). Plan to go to a parts store and have them use their equipment to scope out the particular code problem and repair.
Any experience out there would be appreciated, please?
Old Jan 20, 2003 | 12:40 PM
kspilkinton's Avatar
kspilkinton
When you get the codes, pick up a Chilton's. They have the code descriptions. Post the numbers and code descriptions and we'll help narrow down your problem.
-Kerry
Old Feb 12, 2003 | 06:30 PM
tnscrew's Avatar
tnscrew
i had a "check engine soon" come on. don't know if that is same as your light. i was on interstate and drove less than 20 miles to a dealer. a fuel injector stuck open and the engine bent a rod. few more minutes and it would have completely destroyed itself. in my case that would have been preferrable. ford would have had to give a fresh engine on that. its a new supercrew lariat with a fresh rod and piston.
Old Feb 12, 2003 | 08:39 PM
xcopterdoc's Avatar
xcopterdoc
Your "Check Engine Light" coming on could mean anything. I agree, have the codes pulled at your local autoparts store and go from there. Just because the CEL comes on does not mean it is going to self destruct! I maintain several 4.6's where I work with well over 120,000 on each. The most common CEL code is a misfire on a cylinder. Check the codes and get back to us, we'll go from there.
