Exhaust manifold and exhaust quoted $2300?
#46
Received 1,000 Likes
on
What brand header do you prefer/use?
I've wondered if the skill of the person installing the exhaust has something to do with it. If there was some tension between the headers and the rest of the exhaust, I could see this causing leaks down the road. (or am I just nuts?)
#47
I use headman long tubes , fit good & no leaks , after about the first 100 mi you need to re tighten the header bolts to the head , after a couple of heat cycles , the collector bolts just need the locking nuts , or just use two nuts to lock them , clearence is important , at least a 1/2 in , i had to grid a little off the right side frame to get the clearence i wanted , thats just how headers are , if you do all that you wont have any problems & are much better than stock manifolds , you just have to do it right....Lew
#50
#53
Yeah, I'm not impressed with the quality of the Hedmans. I have seen that they seem to have a common issue with pin holes in the welds too. I like the JBAs on my Mustang though.
#54
#55
Not wanting to hijack this thread but I too am interested in doing some exhaust mods but cant seem to find headers for my truck. Unless I am missing the boat they dont seem to exist. I looked at vendor websites, summit racing, etc. Can you find them? 97 F250 5.8L 4x4 When searching they show till you get to the 5.8L portion of the search.. If you do find some please post a link or part # and mfg info...
Thanks,
G
Thanks,
G
#57
Well went on craigslist the other night and found a few shops looking for work, as well as a few out of work mechanics. Got a quote of $191 for labor from a shop for both manifolds and a quote of $125 labor for both manifolds from a mechanic looking for some side work. I will probably go with the shop just for piece of mind. Well worth the $191 to me to not have to deal with it. I am still debating on stock manifolds or headers, for cats I will most likely just go stock from Autozone, $250 for both cats as an assembly, and this cat back from summit. Summit Racing SUM-684012 - Summit Racing® Cat-Back Exhaust Systems - Overview - SummitRacing.com
I just need something that will work and pass. The crack in the manifold is bigger now and runs ok cold but once it warms up i have absolutely no power. Thanks for the help
#58
on
Thanks,
G
Thanks,
G
#60
