62 Ranchero no spark
Old 01-27-2010, 11:11 AM
tlrrob1000's Avatar
tlrrob1000
tlrrob1000 is offline
Hey there new to the forum.
Have a 62 Rnchero 170 6 cyl. Started running like crap and then changed cap, rotor,plugs, wires and points. NOw there is no spark. Leaning towards balast resistor wire or coil. Have not gotten there yet. Also if anyone has specs ie; point gap, timing thanks in advance.
Old 01-27-2010, 05:33 PM
jschira's Avatar
jschira
jschira is offline
No ballast resistors in these cars.
As you suggest, it might be a bad coil. Aftermarket coils are cheap.
Point gap is 0.024"-0.028"
Timing is 6* BTDC for the stick, 12* for the auto.
Old 01-29-2010, 08:34 PM
Fordranchero's Avatar
Fordranchero
Fordranchero is offline
The wires going to and at the coil are notoriously crappy, I would take a close look at them.
Old 02-05-2010, 07:36 AM
stockcar1974's Avatar
stockcar1974
stockcar1974 is offline
Have your wife hold the coil wire in one hand and to hold onto the negative battery terminal with the other. then crank it over. If she says she wants a divorce, your coil is good,
Sorry I couldn't resist. The other guys have given some good advice. Where did you buy your parts? I have bought ignition parts from advance before and had the rub block on the points fall off. Which caused a backfire that blew my muffler apart. Only buy my points from NAPA since
Old 02-05-2010, 04:59 PM
Fordranchero
Almost forgot, if the problem isn't solved yet, change the condensor.
Old 02-05-2010, 11:52 PM
tlrrob1000's Avatar
tlrrob1000
Ya took care of it last Saturday. It was the balast wire. Ignition to the coil. Adjusted points and timing and all is good.
Thanks,
Rob
Old 02-06-2010, 07:18 AM
Fordranchero
I,m puzzeled, these cars never had a ballast resitor on them.
someone added one?
Monkeyman68
1999 to 2016 Super Duty
09-04-2014 01:16 PM
smith2650
02-22-2011 12:27 AM
tjs_79ford
09-20-2009 11:30 AM
WA62F100
04-20-2000 11:18 PM
Quick Reply: 62 Ranchero no spark
