Bushing replacement
Old Jan 23, 2010 | 01:00 AM
Shade's Avatar
Shade
Bushing replacement
How hard is it to replace the sway bar bushings? I pulled my sway bar off a while ago because the bushings were shot but was then told that I needed torch to get the old bushings out. I kinda threw the sway bar in a corner of hte barn and forgot about it but would really like to put it back in. Are they really that hard to replace? Thanks for the help as always.
(no I don't have a press either)
Old Jan 23, 2010 | 01:10 AM
mueckster's Avatar
mueckster
You can rent/use a ball joint press from a parts house. I used my 20 ton press, though.
Old Jan 23, 2010 | 01:11 AM
WA.Ranger's Avatar
WA.Ranger
Not hard to replace at all. Use a C clamp and a socket if you don't have a press, I think I was able to use my ball joint press one them.
edit, Roland beat me to it!
Old Jan 23, 2010 | 10:34 AM
1975StroppeBaja's Avatar
1975StroppeBaja
The sway bar -to- axle bushings are easy to replace. The end links are just a little harder, only because the originals can be tough to get out. Not bad though.
2004 F250 Sway Bar Bushing Replacement
