weird problem
Old Jan 6, 2010 | 01:45 AM
nikolass's Avatar
nikolass
weird problem
Alright its been like -20 degrees here in Iowa for the past week and Ive been having problems with my truck. Its a 1988 f150 4x4 5sp 300 and when it gets to operating temp while just cruzing holding less than half throttle it starts sputtering like its loosing power. If I push more than half throttle it goes away. It doesn't matter if its in 1,2,3,4,or 5th if im pushing less than half throttle it bogs. As soon as I push the gas it goes away? I replaced: plugs, plug wires, ignition module, coil, fuel filter, checked iacv, tried unhooking the egr by plugging the vac line. Im stumped and this is my daily driver. Ill be doing a compression check tomorrow and also checking the vac lines. any suggestions? Its never done this except when its really cold out. Oh and it idles fine and revs fine.
Old Jan 6, 2010 | 04:29 AM
dustybumpers's Avatar
dustybumpers
might have water in the fuel, add some dry gas, and change the fuel filter
Old Jan 6, 2010 | 04:49 PM
coolguy1419's Avatar
coolguy1419
Try spraying some carb and choke cleaner in the throttle body and make sure those fins are clean.
Old Jan 6, 2010 | 08:09 PM
86sixbanger's Avatar
86sixbanger
computer telling EFI to make the engine run too rich for some reason???
Old Jan 7, 2010 | 03:16 PM
300 Buster's Avatar
300 Buster
Just pulling straws,but after you have checked all the cheap fixes,maybe a throttle position sensor? They are probably not cheap,but they do tell your computer where the throttle plates are.There is probably some resistance checks that could be done but you would have to check the manual,or maybe someone on here could help.I'm not very good at this electronic stuff.
Old Jan 7, 2010 | 03:33 PM
SuperBlue's Avatar
SuperBlue
Does it throw any codes?
Old Jan 7, 2010 | 08:49 PM
chrlsful's Avatar
chrlsful
an '88 has OBDII or whatever that diagnostic thing is? I'd check the linkage/cable from the skinny peddle, cold may = choke, rpm may = ignition? but don't ask me 2 much, aint a mechanic.
Good luck, check back in if still troubles,
Old Jan 7, 2010 | 10:44 PM
88F-150pimp's Avatar
88F-150pimp
It sounds like it could be an oxygen sensor. The computer doesn't use oxygen sensor feedback when the engine is cold, or at heavy acceleration. Just warm cruise, to try to keep the air/fuel ratio at 14.7:1 for lowest emissions. If the sensor is bad, the computer could be overcompensating for a false AFR reading during warm cruise, causing a sputter. As far as I am aware, all other EFI sensors are used all the time.
Pre '96 EFI uses OBD 1. You can pull codes by grounding the STI pin of the test connector under the hood, and turn the key on. It will flash error codes through the check engine light. There are many writeups around on how to do this, and it only costs 1 piece of wire. Personally, I think it's a pain in the a$$, so I just got a code scanner that can handle obd 1 codes.
Old Jan 13, 2010 | 10:03 PM
nikolass's Avatar
nikolass
Just did a compression test on the truck it was from the the front to the back 140,140,150,120,150. The truck has 189,000 miles. I put oil in the chambers and it changed the numbers a small amount. I am going to run the self test for codes and post them up
Old Jan 27, 2010 | 02:09 AM
raylomas's Avatar
raylomas
probably a coolant temp sensor......thats what id be looking at first
Old Jan 28, 2010 | 10:59 PM
nikolass's Avatar
nikolass
I figured out what it was. It was a corroded wire that cam off the negative terminal on the battery that connects to two different wires it was barely connected. I had trouble with it before... runs like a rapped ape now!
betard_foosier
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 19, 2014 05:25 PM
march
15
Jun 22, 2013 09:48 AM
phurst
Apr 26, 2011 02:22 PM
phurst
Apr 19, 2011 12:27 PM
BRay09
Oct 28, 2010 12:15 PM
