Header Problem
Old Dec 30, 2009 | 08:17 AM
oldblueaz's Avatar
oldblueaz
Header Problem
I have a 1968 Ranger. I have put a 400 in her and I cannot find a driverside header that fits past the manual steering bo have tried two diffrent ones). I have a 4wd set and a 2wd set. The 4wd set goes under the crossmember and the 2wd set goes over. There is not enough room for the 2wd set to go in between the trans (c6) and the frame on the passenger side. The 4wd is a way better fit under the crossmember. On the driverside I either one hits the steering box. Any help?
Old Dec 30, 2009 | 12:02 PM
jowilker's Avatar
jowilker
Couple questions, is your truck 2wd or 4wd?
What application are you using?
John
