Truck would not start at work the other nite. My dp-tuner display doesn't come on and no power to the glow plugs or the fuel pump. Replaced the cps thinking that was it but still no-go. Do I have a pcm issue ? It gave no indication that day other than the idle was a little rough for a few seconds at a store, but ran fine afterwords. Any help would be appreciated. Thanks, Bill
Check the wiring to your DP switch. Check to make sure the chip is not loose (with the key off and out of the ignition). You can also try swapping the PCM relay for the blower relay. Also does your WTS light come on? Fuse #30 for the fuel bowl heater can cause this too.
Your issue is the PCM is not getting powered up. Probably a fuse or wiring issue.
One of my favorite things to snag when I'm at a truck getting parted out is all the fuses & relays; especially the big MAXI fuses. $10 is what I normally pay for a big handful, but I try to take zip-loc baggies with me to keep them clean. My point is that Chris probably has you pointed in the right direction, and having spare fuses & relays handy is always good. Good luck in finding your issue!! Keep us posted!
I would start troubleshooting by removing my DP chip to make sure something hasn't taken a crap like the PCM.. The DP tuner display is powered by the PCM so if you're not getting power to the display something is wrong.
The fuel bowl heater is not a critical item, even in the cold weather. Tape it up and leave it unplugged until you can fix it at your convenience (if at all). With the heater unplugged, the fuse won't blow again.
I replaced the fuse and turned the key and the WTS lite was on and then off after a couple seconds, fuse blown again. I suspect the bowl heater. The thread about replacing it couldn't have come up at a better time. It will have to wait till later as I have to go to work.
same thing happend to my truck but i was driving i had lights on the dash that wouldnt come on and it wouldnt start just turn over, it did turn out to be the fuel bowl heater but it didnt blow the fuse it ended up being a diode on the pcm that went out corey at randalls performance in gladstone illinois figured it out
I have a 2002 F350 extended cab duly and the brake lights or third light not working.
I can not find a bad fuse and I have replace the brake light switch. Can anyone help me.
If you can't, we'll try to talk you through it, but some basic electrical skills will be needed.
That twenty-amp fuse #18 looks kinda' suspicious. It's location can be found with the use of the diagram in the Owner's Manual.
First, unplug the brake light switch that you replaced. Test the fuse by using a voltmeter on each of the wires in the plug to the brake light switch. One of them, the LT GRN/RED, should have 12 volts. If not, leave the plug off the switch and replace that fuse, even if it looks good.
Then, re-check that wire for voltage again. If it doesn't let us know.
If it's now got voltage, plug it back into the switch and step on the pedal.
Check that fuse yet again and and let us know.
BTW, there are no additional fuses upstream to the battery, just one fusible link, which if popped would render a whole bunch of other things inoperative, so it's good.
