Engine I.D.
Old Apr 29, 2000 | 09:08 PM
Russell Leonhardt's Avatar
Russell Leonhardt
Engine I.D.
Is it possible to decode this engine from this number on the intake? C6AE9425-H
Thanks,Russell
Old Apr 30, 2000 | 08:00 AM
Clax67F100's Avatar
Clax67F100
Engine I.D.
there will be raised lettering in the metal of the engine block. You have to look for it, they are not all in the same place. You might have to use some engine de-greaser. The way ford started numbering engines was like this:
The first letter corresponds to the decade...
A=1940's
B=1950's
etc.
and the number corresponds to the year...
so for example if the block says....
C5******
it is a '65 engine.
hope this helps...
Clax
Old Apr 30, 2000 | 05:56 PM
StockMan's Avatar
StockMan
Engine I.D.
[FONT COLOR="#0000ff" SIZE="+1" FACE="Tahoma"]It is not a good idea to rely on the intake casting code alone to id an engine because that particular part is easily changed and the same part may have multiple applications. To get the full picture, we need the block casting code and date codes from the major components. I like to get the numbers from as many parts as possible, including the heads, intake, exhaust manifolds and block, amongst other items.
We have a similar thread started on this subject elsewhere. We probably should merge these two discussions. [/FONT][BR]
http://www.dealerconnection.com/DealerConnection/Themes/Standard/Ford/lgo-ford.gif[BR][BR]
[FONT COLOR="#ff0000" SIZE="+2" FACE="Bassett"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="-2" FACE="Tahoma"]
1967 F-250 FE 390 4wd LWB Styleside
1966 F-250 I6 240 2wd LWB Flareside
http://www.hometown.aol.com/tbeeee
Old Apr 30, 2000 | 07:05 PM
StockMan's Avatar
StockMan
Engine I.D.
