wiring problem 1989 f150
When parking lights are on, brake lights on also, or when I brake the parking lights, dash lights ,etc are activated. Turning on signal indicator, dash lights, etc also flash. Replaced headlight switch, no change. Wired light grounds directly to bat neg, no change. Disconnected dimmer switch, no change. Any help would be appreciated. BTW called Ford svc dept, explained problem was told the mech's had no idea what problem was.
at some point in it's life, someone has hooked up trailer lights. they have shorted out, because they are corroded. look under the bumper, and in that area, any wireing that is not factory, remove it, and your problem is solved. I have run into this so many times, as soon as someone says the dash lights come on when I brake, that's the first place I look
aardvark
1997 - 2003 F150
34
01-05-2017 07:31 AM
wagonerkl
01-12-2014 03:26 AM
GKarEMC
1983 - 2012 Ranger & B-Series
08-15-2007 12:44 PM
