Sponsored by: Auxito
ABS Light
Old Nov 23, 2009 | 07:18 PM
david350's Avatar
david350
ABS Light
Mine on the dash is always on. My mechanic niehbor and I hooked it to a code reader, no codes for anything on the truck...
He said it could be a fuse, or either sensor on each front wheel.
What would you guys try first? Any advice?
Thanks.
Old Nov 23, 2009 | 09:01 PM
thecardoc's Avatar
thecardoc
Hook it up to a ABS code reader ,they are different than regular engine reader . If the dash ABS light is on there should be code there . Once the cause of the code is repaired the codes need to be cleared using reader . The most common cause of the ABS light seems to be a bad rear Diff speed sensor which is on the top of the diff . These sensors are cheap and can be purchased at any parts store .
