460 Carb to EFI
Old 11-07-2009, 07:06 PM
driller tom's Avatar
driller tom
driller tom is offline
460 Carb to EFI
Hey guys I just picked up an 88 fuel injected 460 and I also have an 86 carb 460... I was wanting to see if I could use the EFI out of the 88 into the 86, I plan on swapping the zf5 trans out of the 88 into the 86. Is it possible to also swap the EFI?
Old 11-07-2009, 11:37 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
You could swap the EFI, you'd just need to swap the harness and computer over
Old 11-08-2009, 08:33 AM
driller tom
Thanks!! Has anyone ever this before and how hard will it be?
Old 11-08-2009, 10:06 AM
Lead Head's Avatar
Lead Head
Well most of the harness just unplugs at some point in the truck, the under hood wiring probably wouldn't be a big deal, but ripping out all the wiring in the dash will probably get annoying.
fordfuelinjection.com has some schematics of the EEC-IV computer's connection, so you could also take only the wires and connectors you need and transplant them into the older truck and make a "custom" harness.
Old 11-08-2009, 10:17 AM
driller tom
I was planning on just swapping motors.... Could the 88 dash fit in the 86?
Old 11-08-2009, 11:47 AM
Lead Head's Avatar
Lead Head
It doesn't matter, you would still have to pull all of the wiring out of the 88 and transplant it to the 86
